> Do I need a new CAT?
post Sep 29, 2006 - 4:11 PM
ShadowPhantom
Joined Oct 19, '05
When I first start the car and give it some gas the car sounds like a gurgling terd. Once it warms up it is much less noticeable. Sounds almost like a little marble bouncing around by the exhaust manifold with a bit of a sputtering sound. It only does it when it is in gear not when you rev the motor.
Anyone have any idea what needs to be replaced? CAT or manifold?
post Sep 29, 2006 - 4:20 PM
6gc94celi
Joined Sep 6, '06
Maybe u need a new spark plug..check to see
post Sep 29, 2006 - 4:25 PM
could be a crack in the cast iron manifold. the 7afe cast manifold is known to crack, usually between 3/4 or 1/2.
post Sep 29, 2006 - 4:26 PM
DomGT
Joined Apr 19, '06
From Long Island, NY
QUOTE(ShadowPhantom @ Sep 29, 2006 - 5:11 PM) [snapback]485417[/snapback]
Neither, before you replace expensive stuff, I'd start with a tune-up, new spark plugs, wires, and O2 sensors.
'92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold
'99 Black Mitsubishi 3000GT VR-4 - Sold
'04 E250 Work Van - Going soon
'08 Grey Dodge Charger Work Car - Ordered
post Sep 29, 2006 - 4:36 PM
ShadowPhantom
Joined Oct 19, '05
QUOTE(DomGT @ Sep 29, 2006 - 5:26 PM) [snapback]485426[/snapback]
Actually it has a new cap rotor, plugs, wires, and I put a new O2 sensor in about 2 months ago (had a cell light). It was the 2nd sensor that is at the bottom by the firewall. What I PITA that was! Had to cut the old one off to get at the stripped bolts. Right by the O2 sensor on the exhaust pipe there is this little mesh tubepiece. It kept poking me. What is that? It sure looked beat to hell. The car is a 95. I thought it only had one O2 sensor? Does that mean it is a California emissions car?
It does not seem to effect the performance of the car. It idles pretty good. Just sounds really bad.
post Sep 29, 2006 - 5:13 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
It kinda sounds like the problem I had a couple years ago. I thought it may have been my valves, but I don't know what the exact problem was because I ended up having the entire motor built from the ground up.
post Sep 29, 2006 - 5:18 PM
DomGT
Joined Apr 19, '06
Well if it had a tune-up recently, it's more than likely the exhaust system. Maybe you could use a gel-like liquid that bubbles up, to find the leak?
2 O2 sensors could be a Cali-spec car.
post Sep 29, 2006 - 5:56 PM
all USDM STs have 2 02 sensors, they are all cali-spec.
post Sep 30, 2006 - 8:18 AM
ShadowPhantom
Joined Oct 19, '05
QUOTE(DomGT @ Sep 29, 2006 - 6:18 PM) [snapback]485455[/snapback]
What about the fact that the noise stops after I drive it for a while. Once I get off the freeway on the way to work (about 35 miles), when I take off from a stop it is almost unnoticeable. Let the car sit for a couple of hours then it sounds like crap again.
post Sep 30, 2006 - 8:31 AM
DomGT
Joined Apr 19, '06
I have noticed that when I had an exhaust leak too. My guess is that when the exhaust system heats up, it expands, closing the leak.
Soon though the damage will worsen.
post Oct 1, 2006 - 12:35 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
QUOTE(Bitter @ Sep 29, 2006 - 2:25 PM) [snapback]485425[/snapback]
I second this. I bought my car and then found the leak. It could also be the flex pipe.( the little mesh tube piece) Those are bad about leaking that could be caused by bad front or rear engine mounts. It is supposed to flex a little but if your mounts are worn then it is flexing it any time you change gears or accelerate.
Easy way to check these is to: for the manifold just remove the heat shield and inspect it, for the flex pipe you need to jack the car up and feel around it while the car is running.
Good luck and ask more questions if you have any.
post Oct 1, 2006 - 1:22 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
If it were sounding more like a rasping/light rattling sound, then I would agree with bindertch on the flezpipe issue. When I first got my gt it was making a sound like that. Replaced the flex-pipe and no more bad sounds.
post Oct 1, 2006 - 7:44 PM
ShadowPhantom
Joined Oct 19, '05
QUOTE(6gsillyca @ Oct 1, 2006 - 2:22 PM) [snapback]486011[/snapback]
Maybe it is the flex pipe then. I remember checking it out when I changed the O2 sensor. It looked pretty knarled up. It was so frayed up that it kept poking my hand.
What is the part # and do I need to order it from Toyota? How do you remove and install?
Thanks Again,
Chris
post Oct 1, 2006 - 9:10 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
QUOTE(ShadowPhantom @ Oct 1, 2006 - 5:44 PM) [snapback]486140[/snapback]
Thanks Again,
Chris
You will probably only be able to order the whole bottom end pipe. It might cost less to just have an exhaust shop put one in. I just looked and it isn't cheap but it is a bolt in part.
post Oct 1, 2006 - 11:50 PM
you can get a flex section welded in at just about any muffler shop.
post Oct 2, 2006 - 8:48 AM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Hammer punch the muffler and see if you hear anything rattling around... toasted cats tend to chill in the muffler
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
Lo-Fi Version Time is now: January 10th, 2025 - 8:04 AM
