> choose rite clutch....
post Oct 2, 2006 - 8:34 AM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
im puttin in my 3sgte and im using the 5sfe tranny and tring to figure out witch clutch for me to use or wat nott... any1 have suggestions on how to go about doin this...
post Nov 7, 2006 - 7:30 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Im in the same boat as you. I want a clutch that will hold up to the x-tra hp.
post Nov 7, 2006 - 9:35 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
use the spec stage 1 or 2 clutch! ITS THE ONLY WAY TO GO!!!
post Nov 7, 2006 - 9:42 PM
jdg371
Joined Jun 14, '05
Anything thats not stock. HAHA
Stage 2 or 3 are fine. You can go with ACT, Centerforce, Exedy... etc
http://www.autopartswarehouse.com/performa...&partid=137
thats where I got mine. Just make sure it comes with everything to do a clutch job lol.. mine didnt come with an alignment tool.. good thing I had one for the 4AGE
This post has been edited by jdg371: Nov 7, 2006 - 9:44 PM
post Nov 28, 2006 - 1:44 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(easternpiro1 @ Nov 7, 2006 - 9:35 PM) [snapback]500421[/snapback]
Im not sure how to tell the difference between stage 1-2-3. Do you have a part# for the act stage 2? Is it ok for a daily driver? I need a clutch soon. Thanks!
post Nov 29, 2006 - 1:41 PM
rzanology
Joined Apr 25, '05
From nyc
grip fource stage 3 works for me. pulls every gear like it wasd 1st
post Nov 29, 2006 - 1:55 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Hey,
Has anyone had any problems with using an oem toyota 5s-fe clutch disc and the rest high performance or oem for the 3sgte? I dont want a full racing clutch because this is my daily driver. Ive been talking to ACT and they can only go stock organic or full racing 6 puck with no sprung hub. Im so confused. Im about to say screw it and get a clutch from toyota. Ive got a trd pressure plate that came with the motor. What should I do?????????? This is my daily driver......Thanks!!!!!!!!!!!!!!!!!!
post Nov 29, 2006 - 2:20 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
The Spec Stage II that Dr. Tweak put in with my swap is holding together marvelously. Chirp Third anyone?? biggrin.gif
post Nov 30, 2006 - 1:29 AM
masterluie214
Joined Oct 5, '06
From dallas tx.
im about to upgrade my clutch from stock.... been having some problems with it and from what i know about clutches is after market or racing clutches are way better to get then stock cause you will have to change the stock one out sooner and if you got a any kind of racing clutch as long as you dont race it you should be fine and it will give you that exrta pull if you want to race or if your just trying to pass someone very quickly im not saying that im an expert on all that but thats me.... my car is my dayly driver as well i also and im thinking of going to stage 2 or 3 ....and had a honda single cam that had a stage 4 clutch and it ran just fine just thought i would put in my input think about it....
post Nov 30, 2006 - 1:34 AM
rayneezy23
Joined Jun 25, '06
From Bremerton, Washington
i just bought a new clutch set its a duralast
post Nov 30, 2006 - 2:03 AM
6gcSTVT
Joined May 3, '06
From New Hampshire
QUOTE(Fastbird @ Nov 29, 2006 - 2:20 PM) [snapback]506363[/snapback]
Darin H.
Lo-Fi Version Time is now: December 9th, 2024 - 5:51 PM
