> Some Observations on Using OEM Toyota 4 Piston Calipers
post Oct 7, 2006 - 5:57 PM
I was at the junkyard today browsing for something new for one of my cars, and I came across some trucks, which got me thinking about some comments some members had made a while back about using some 4WD Toyota four-piston calipers on the front of a sixth gen. Celica.
Some interesting facts:
  • The caliper bracket's two holes to mount it to the hub/spindle are much closer together than on our sixth gens. This means that the caliper bracket and caliper can't bolt to a stock sixth gen. Celica hub/spindle.
  • The trucks I found these four piston calipers on use a [url=http://www.buybrakes.com/store/BR25508]vented rotor that's 18mm thick[\url]. The [url=http://www.buybrakes.com/store/BR25425]ST204's vented rotor[\url] is 26mm thick. ST185 rotors are 23mm thick, as are AT200 rotors, but I'm sure the the ST's rotor isn't a large enough diameter. That said, it looked as if 5mm thicker rotors could fit in the calipers, but that may be because the used rotors and pads were worn down on the calipers I saw.
  • The trucks I found these calipers on also use a 289mm diameter rotor. This could mean that even a ST204 or ST185 rotor (275mm and 277mm, respectively) may not be a big enough diameter rotor. However, they might work, depending on how the four-piston caliper bracket was custom-mounted on a sixth gen.
  • The four-piston calipers use a different sort of brake line. A small portion of it is rubber, from the body to the hub/spindle, and then from there, the brake line turns back into a hard line until it hits the caliper, with a 10mm connection similar to the ones found where the rubber brake line meets the hard line on our sixth gen. Celicas. One might be able to use the truck's brake lines and just bend the hard part of it to get it to work.
In the end, this conversion may be possible, but I'm not going to be the one to try it. You'd have to drill and tap at least one additional hole in your hub/spindle to get the caliper bracket to bolt up. At that point, you'd probably want to try a ST185 rotor or a similar large-diameter vented 5x100 rotor that's closer to 18mm thick, which may be too thick for the caliper, or too large/small of a diameter for the four-piston caliper.
Then there's the issue of the caliper being in the right place for the rotor to slide into place. While spacers could help and probably solve the problem if the caliper is out too far, if it's in too far, you'd be in for a lot of fabrication work. Then you'd have to figure out brake lines, though I have a feeling the truck's lines could be used if modified properly.
But if someone wants to try, it may be worth it in the end. You may be better off getting ST205 four-piston calipers, but those are much harder to come by and more expensive, and they require some modification as well I believe, though not as much.
Four-piston calipers can be found on several Toyota 4Runners and trucks with 4WD and V6 engines, and probably more Toyotas. I found four-piston calipers on a '95 truck with 4WD and a V6 and on a '88 4Runner with 4WD and a V6 also. The junkyard wanted $25.00 per caliper had I bought them.
Just figured you guys might want to know. Post up if you've got any more information or questions. smile.gif
post Oct 8, 2006 - 12:20 PM
rotors arent an issue at all, just get the specs you need and contact Stoptech, they should be able to get you a part number for the correct rotor or make a pair for you.
post Oct 8, 2006 - 7:28 PM
toyotatech
Joined Jun 14, '05
From colorado
i was thinking about this too, and next week i'll have a set off of an 06 tundra i was just put my car in the air and see how far off the mounting holes are.
post Oct 8, 2006 - 8:08 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Yeah when I added cross drilled rotors to my 4runner, I thought it was kinda funny that it had a better caliper than my Celica. I never thought to see if they are interchanable.
post Oct 8, 2006 - 8:13 PM
celica47
Joined Feb 3, '05
From Tampa, Florida
well even if they work for sure, would the braking power be noticeable?
I'am Reinventing the SLow Lane.....
post Oct 8, 2006 - 8:39 PM
also keep in mind that this 4 pot caliper may need a larger fluid displacement than your master cylinder can provide.
post Oct 9, 2006 - 3:20 PM
QUOTE(coldbluesteel @ Oct 8, 2006 - 6:08 PM) [snapback]489196[/snapback]
It makes sense, considering the 4Runner is much, much heavier than our Celicas. wink.gif
QUOTE(celica47 @ Oct 8, 2006 - 6:13 PM) [snapback]489200[/snapback]
I would think so, but again, I'm not sure.
QUOTE(Bitter @ Oct 8, 2006 - 6:39 PM) [snapback]489214[/snapback]
I thought about that, and after reading this and this, the master cylinders weren't replaced with different units in either case, and in both cases there are no complaints.
Though both of those cars used two-piston calipers initially I believe, so yes, we may need a bigger-bore master cylinder. Not sure though.
post Oct 10, 2006 - 8:22 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
My only complaint with the truck's 4 pot calipers... they're built for much thinner rotors. Because the rotors are thinner... it'll affect cooling more than anything else. IMO... if you're gonna go through the trouble... ST205 calipers or even mkiv Supra calipers are more worthwhile. Truck calipers are cheaper and more plentiful... however. I haven't really had a good look at the newer calipers on the bigger trucks either (tundras, sequoia, and landcruiser)... but they are different and might be much thicker.
post Oct 10, 2006 - 8:42 PM
toyotatech
Joined Jun 14, '05
From colorado
i know the tundra's and the sequoia's have 318mm x 28mm rotors
post Oct 10, 2006 - 9:29 PM
coomer, an easy way to check this is to CC the stock caliper at rest and at fully extended (pull it out with something) and then find the difference, this is how much fluid the master cylinder will ever have to move to put it all the way out there. then do the same with the 4 pot. you can just do one side at a time tho or one pot at a time, just be careful with the math as it could get a little tricky keeping track of 4 displacements. if the displacement of the stock is close to the displacement of the 4 pot then it shouldnt be a problem. if its alot more then you'll get low pressure in the 4 pot calipers at max pedal stroke and probably be locking the rear brakes before the fronts can bite. to fix that you could try swapping a truck master on over....but then you have to do something about the rear brakes, what does the donor truck have out back? is that fluid displacement near what your stock rear brakes need?
Lo-Fi Version Time is now: February 13th, 2025 - 5:59 PM
