> Two problems I can't figure out, noises while driving
post Oct 9, 2006 - 10:39 PM
dawnoforigin
Joined Oct 17, '05
From Tucson, AZ
I'm more of a reader than a poster around here, but I've got a few problems I can't put my finger on. Firstly, whenever I start up my '95 Celica gt and then I immediately brake there is this clank noise. This happens as soon as I push in the brake and am going at a very slow speed. Oddly enough, after the car warms up, the sound dissappears. Now I haven't checked my brakes in a while, but last time I looked they still were in decent condition; the rotors also look fine to me. My second issue seems to be another cold start problem. Again, while driving at slow speeds, I can hear each rotation of one of the rear wheels. Every rotation there is this clicking noise. Like my first problem, it seems to go away after the car warms up or if I drive at a faster speed. My Celi's got 65, 0000 miles so far....Any help or suggestions will be greatly appreacited.
This post has been edited by dawnoforigin: Oct 9, 2006 - 10:44 PM
post Oct 9, 2006 - 10:48 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
o boy, bearing, cv joints, warped rotors and bad brakes. and a bad o2 sensor
post Oct 9, 2006 - 10:55 PM
dawnoforigin
Joined Oct 17, '05
From Tucson, AZ
I will recheck the brakes, but the rotors don't appear to be warped...the CV joints were my initial concern....thanks the reply.
post Oct 9, 2006 - 11:13 PM
LewFX
Joined Jan 28, '05
braking clank noise is bad brakes...clicking is cv joints or bearings...and o2 sensor as said earlier
post Oct 10, 2006 - 8:46 AM
toyotatech
Joined Jun 14, '05
From colorado
there is a TSB for the front brakes clicking, if thats what your hearing there is nothing wrong with your brakes its just annoying.
post Oct 10, 2006 - 2:59 PM
Alex-UKSC
Joined Jul 23, '06
From Chester - UK
Mine does the same & i was told it's some tensioner thing with the brakes kindasad.gif
My Celica Is Now For Sale
post Oct 11, 2006 - 7:14 AM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(LewFX @ Oct 10, 2006 - 1:13 AM) [snapback]489782[/snapback]
-Rémy
02 SiR, 08 250R
post Oct 11, 2006 - 9:22 AM
LewFX
Joined Jan 28, '05
QUOTE(Rayme @ Oct 11, 2006 - 5:14 AM) [snapback]490235[/snapback]
This post has been edited by LewFX: Oct 11, 2006 - 9:22 AM
post Oct 11, 2006 - 9:28 AM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
lol yup i think its normal.
i got that little thing too, i wouldnt call it a problem.
it just sounds like a clamping noise. obviously thats what the brakes do, they clamp on to the rotor.
it happens sometimes, not all the time.
its like a "Clamp" short but not really noisy.
Is this good enuff 4 ya? :D
post Oct 11, 2006 - 10:59 AM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(LewFX @ Oct 11, 2006 - 11:22 AM) [snapback]490256[/snapback]
Well you didn't elaborate too much..I thought you only have some wheel noise when the car has been sitting for a while(cold start)
And the o2 sensor has no relation to cold starts at all!! It needs to be really hot to work, and thus has no relation to cold start…The computer ignore the sensor’s output until a few minutes after the car has started.
This post has been edited by Rayme: Oct 11, 2006 - 11:02 AM
-Rémy
02 SiR, 08 250R
post Oct 19, 2006 - 2:19 PM
dawnoforigin
Joined Oct 17, '05
From Tucson, AZ
QUOTE(XS4lv1Truch0x @ Oct 11, 2006 - 9:28 AM) [snapback]490258[/snapback]
Yeah, that's essentially the noise it makes. I've never heard other cars make a similar sound, so that's why I was assuming something was wrong. If that's just the way it is....that's the way it is.
I also got around to checking my brakes. Both front and rear have well over 50% pad left so it can't be that. I still think my rotors are fine as well because I've been told your steering wheel would vibrate a lot while braking if they were warped.
Thanks for the replies.
This post has been edited by dawnoforigin: Oct 19, 2006 - 2:21 PM
post Oct 20, 2006 - 12:55 PM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
i had a problem similar to that.
my brakes clicked the first time i used them. i did some tests, and they did it anytime i changed directions.
it was just my pads moving around. some silicone between the pad and piston took care of the noise.
post Oct 25, 2006 - 9:33 PM
RisingSun1
Joined Sep 29, '06
From US
my celi does the same thing, you should check your pad retaining clips, sometimes they get a little rusted and they dont hold the pads in place very well.
Lo-Fi Version Time is now: November 23rd, 2024 - 11:59 AM
