HID Kit install (JDM H1) |
Oct 19, 2006 - 7:41 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
If you are in the HID group buy, and you purchased the H1 for the JDM headlights, the first thing you'll notice is that the HID bulb does NOT fit into the black housing (socket) from the original bulb.
Second is the bulb (the glass part) does NOT fit through the space. Any help is greatly appreciated. -------------------- |
Oct 19, 2006 - 8:01 PM |
Enthusiast Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
can you doble check that the bulb is a H1. Maybe the company made a mistake when they sent you your kit and it's not a H1.
Oct 19, 2006 - 8:09 PM |
Enthusiast Joined Dec 21, '05 From dallas Currently Offline Reputation: 3 (100%) |
Hell yea someone make sure. Because i ordered H1 for the projecters. The HID hasnt got here yet, so patiently waiting. The guy that lives about 20mins away from me got his today. Werid.
Oct 19, 2006 - 8:15 PM |
The label says H1. The actual bulb, however, doesn't metion anything.
Oct 19, 2006 - 8:17 PM |
I read somewhere on the site that there are two types of H1.
can someone do a little research on this to verify ? -------------------- |
Oct 19, 2006 - 8:18 PM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
i got the same thing as tomaz, will try to fit it tomorrow.
This post has been edited by LewFX: Oct 19, 2006 - 8:21 PM -------------------- |
Oct 19, 2006 - 8:49 PM |
Enthusiast Joined Jul 9, '04 From Las Vegas USA Currently Offline Reputation: 14 (100%) |
Oh man I got H1 also and mine looks just like the one in the pic. I don't have my projectors yet to test fit them so I hope we can resolve this before my projectors arrive.
Oct 19, 2006 - 9:09 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
If you are VERY careful, it will go in. keep in mind, there are pegs on the base of the bulb, and they have to go a certain way. i BELIEVE that the rounded side of the bulb's base goes toward the inside of the engine bay, and the flat side faces toward the fender. The acrylic rod should be on the bottom. If you VERY gently rock the bulb, it will slide through, and then just be very very careful after that. As far as the base, I was confused about this too, but you do not need the "adaptor" that the normal halogen H1s go into. Just slide the bulb all the way in, and then clamp it into place with the small metal clamp. Then, personally, I slid the other washers and what not all the way up to the bulb, and then put on the rubber boot that goes on the backside of the projector housing. As far as there being two H1 types, I believe I have the other, as my HIDs have opaque "washers" around them, and the acrylic rods are white, instead of blue. If anyone needs anything else, feel free to PM, IM, or email me. -John- -------------------- |
Oct 19, 2006 - 9:51 PM |
Enthusiast Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
trying to help you out here... found a few picture of H1 bulbs. It does appear that there is only one standard bulb type for H1. So looking at your pictures.... im wondering Cant that white plastic around the cord do the job of the spider like clamp ? And as for the bulb not fitting... if you have rotated it every way and it will not fit... perhaps enlarge the hole with... a drill of some sort .... or a better method
This post has been edited by phonex98: Oct 19, 2006 - 9:56 PM -------------------- ----- '94 ST hatch --- Yellow ----- |
Oct 19, 2006 - 9:55 PM |
the top 3 pics are like the ones we got. How come they are so different?
mispost
Oct 19, 2006 - 11:15 PM |
I knew I saw this before, here is a link to an previus discussion with what appers to be a possible solution !
H1 Issue I hope this helps. -------------------- |
Oct 20, 2006 - 12:00 PM |
Enthusiast Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
WOOT WOOT just got mine 10 minutes ago!! but i gotta go to work so I'll try and install these bad bosy tonight. THANKS STEVENSON!!!!
Does anyone have a fix for the H1 bulbs not fitting in the JDM h1 housing yet? |
Oct 20, 2006 - 12:16 PM |
Oct 20, 2006 - 12:55 PM |
SUCCESS!!! woo hoo, ill be posting my own thread
Oct 20, 2006 - 11:46 PM |
I did read the "h1 issue" thread, and it didnt seem like there was an "absolute" solution...
Will try what Lew posted and see if that works! |
Lo-Fi Version | Time is now: January 10th, 2025 - 4:46 AM |
