> 3sgte with GT Tranny., I need sugestion on clutch
post Nov 8, 2006 - 9:44 AM
y2komar
Joined Sep 21, '06
From New York City
what's up.
I am in the process of gathering all needed parts for my 3sgte swap to 94 GT
Okok ok
From what I read i will need a GT clutch disk and I a pressure plate for a 3sgte engine... RIght??
Well can anyone give me suggestion on what to buy.
Part numbers will help greatly, and maybe a good place to buy them.
thanks everyone
I have a 2nd gen 3s from japan. Are all 2nd gen all the same
post Nov 8, 2006 - 9:58 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Spec clutch actaully has a kit they sell specificly for this setup i am also using it. a couple others are also. call or Email spec and they can help you out. i suggest a stage 3 even if u dont need it.
This post has been edited by x_itchy_b_x: Nov 8, 2006 - 10:07 AM
post Nov 8, 2006 - 11:06 AM
y2komar
Joined Sep 21, '06
From New York City
ok i went to spec clutches and send them a email.
The clutch that i have is still very good and does not slip one bit.
I believe it is a ACT setup.
Can I use the pressure plate that i have and just buy a new disk?
remember im keeping my GT tranny but keeping the 3sgte flywheel
post Nov 8, 2006 - 11:12 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
yeah i have the same setup as what your going for. 5sfe s54 tranny with a jdm 3sgte. it will be fine. might aswel buy the whole clutch setup, there are different clamping loads for every clutch setup. its up to you though. i mean you could, but who knows how long it would last esp since its meant for the power of a 5sfe not a 3sgte.
post Nov 8, 2006 - 11:26 AM
y2komar
Joined Sep 21, '06
From New York City
ok
So the bolt pattern on a gt preassure plate is the sam as the 3sgte plate.
I am going crazy looking for a gt disk and a 3sgte preassure plate.
Can I just buy a entire setup for a gt. with a stronger plate and disk. Higher stage.
Thank you again
post Nov 8, 2006 - 11:35 AM
read the stickies, its all in there. you can call up a company like spec, tell them that your doing a 3sgte swap with a gt tranny, and they will sell you a custom clutch kit with everything you need.
Lagos wrote:
Clutch:
if using the gt tranny with the 3sgte motor, you will need:
5sfe disk (or a custom made 3sgte disk, with the splines for the 5sfe tranny)
5sfe throwout bearing
5sfe alignment tool
3sgte pressure plate
3sgte flywheel (or just get your stock one resurfaced)
if you are going to use an mr2 turbo tranny, then all you need to do is buy a clutch kit for a 90-93 turbo mr2.
becareful when buying clutch disks for the 5sfe tranny. a stage 1 disk for the 5sfe is not the same thing as a stage 1 disk for the 3sgte. so if you get something like a stock oem clutch or a ACT street disk, it probably will not hold the power you need to put down.
if you call up a company like Spec or Clutchmasters and tell them about your project, they can make you a custom disk that can hold the power you will make and have the correct spline count that you need.
This post has been edited by lagos: Nov 8, 2006 - 11:36 AM
post Nov 8, 2006 - 11:36 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
wait im sorry if i was misleading. the GT Pressure plate will not bolt up to a 3sgte flywheel.
What you need is:
A 3sgte pressure plate
A 3sgte clutch disc with 5sfe tranny splines.
spec sells this as a kit made especially for us.
QUOTE(lagos @ Nov 8, 2006 - 1:35 PM) [snapback]500610[/snapback]
Lagos wrote:
Clutch:
5sfe alignment tool
There we go smile.gif thanks lagos.
post Nov 8, 2006 - 12:07 PM
y2komar
Joined Sep 21, '06
From New York City
Thanks
I thought I have read that somewhere. Now it is clear.
I received the email from spec. This is the email
Yes, you will need our pn ST62_5S, which will get you the correct disc and
setup. Fill in the _ with the stage number you choose. Let me know if I
can answer any other questions.!
I need something durable, considering it is a daily driven car In NYC.
I drive it hard but I don’t burn rubber too often. What do you guys suggest?
post Nov 8, 2006 - 12:21 PM
stage 3
post Nov 8, 2006 - 12:31 PM
y2komar
Joined Sep 21, '06
From New York City
QUOTE(lagos @ Nov 8, 2006 - 12:21 PM) [snapback]500630[/snapback]
stage 3
Thank you
This post has been edited by y2komar: Nov 16, 2006 - 1:10 PM
post Jan 9, 2007 - 2:51 PM
Alan
Joined Jan 23, '05
From Malta
QUOTE(lagos @ Nov 8, 2006 - 11:35 AM) [snapback]500610[/snapback]
Lagos wrote:
Clutch:
5sfe alignment tool
Lagos my celica has a s54 tranny, and my orignial motor was the 3SGE not 5SFE I think it also comes in this model just to clarify. Right?
post Jan 9, 2007 - 4:19 PM
Kadett
Joined Mar 17, '05
From The Netherlands
Yup both are S54 tranny. But the 3S-GE S54 have a smaller differiental. So top speed is a bit higher.
Both if your tranny comes from a Beams engine I dont think a standard 3S-GE/5S-FE performance clutch will work.
post Jan 9, 2007 - 4:28 PM
jcbass7
Joined Apr 20, '06
From Florida
http://www.6gc.net/forums/index.php?showtopic=38069&hl=
that thread is what i wrote after buying the spec kit. might be helpful. has some info from Justin the guy i talked to at spec. His user name is SPEC01
EDIT: I got the stage two clucth, but after driving my swap for a couple weeks now i would not have complained if i had gotten the stage 3
This post has been edited by jcbass7: Jan 9, 2007 - 4:29 PM
post Jan 9, 2007 - 5:18 PM
urbandork
Joined Jul 16, '04
From Los Angeles
i have the spec stg 3 clutch for my set up and it handles the power well.
Lo-Fi Version Time is now: February 18th, 2025 - 11:25 AM
