> 3sgte 3rd gen cel code 414 or 41 4???, blink blink blink hahaa
post Nov 15, 2006 - 12:20 AM
urbandork
Joined Jul 16, '04
From Los Angeles
well i checked my cel today and i got this
(blink) (blink) (blink) (blink) (short pause) (blink) (i think a little longer pause) (blink) (blink) (blink) (blink)
and then a super long pause like normal and then it did the sequence again.
from a later thread it looks like it might be a "41 - TPS Open or short circuit in VTA signal Test Throttle Position Sensor" but whats up with that last four???
btw which book and what page/chapter are the codes in the repair manuls for the gt4
thanks
QUOTE(lagos @ Jul 16, 2006 - 7:23 PM) [snapback]456875[/snapback]
here:
http://celicatech.com/forums/showthread.php?t=10155
3sgte CEL Error Code List
11 - ECU Momentary interrupt in power Check relays, IG switch
12 - RPM No "G" signal to ECU for 2 sec after crank Starting related, check distributor, starter
13 - RPM No "NE" signal to ECU above 1000 RPM Check distributor
14 - IGN No "IGF" signal to ECU 8-11 times Check Igniter, ignition coil
21 - O2 Detection of oxygen sensor detoriation Check oxygen sensor
21 - O2 Open or short circuit in o2 sensor heater Check oxygen sensor
22 - WTR Open or short in Water Temp Sensor Check Water Temp Sensor
24 - AIR Open or short circuit in Air Temp Sensor Check Air Temp Sensor
25 - O2 Excessive Lean Air Fuel Ratio Check o2 sensor and fuel system
26 - O2 Excessive Rich Air Fuel Ratio Check o2 sensor and fuel system
31 - AFM Open circuit or short in VC signal Test or replace Air flow Meter
32 - AFM Open circuit or short in E2 signal Test or replace Air flow Meter
34 - TRB Fuel cut due to excessive turbo pressure Check Wastegate Hose, Test Pressure Sensor
35 - TRB Open or short circuit in Pressure Sensor Test Turbo Pressure Sensor
42 - SPD No "SPD" signal over 8 seconds driving Check Vehicle Speed Sensor
43 - STA No "STA" signal over 800 RPM starting Check Ignition Switch
51 - IDL No "IDL" or A/C signal during testing Check TPS, A/C switch, Accelerator cable
52 - KNK Open or short circuit in Knock Sensor Check for broken/brittle wire, Replace Sensor
54 - INT Intercooler Coolant Low or Pump Failure Replace Water Level Sensor, Test IC W. Pump
71 - EGR EGR gas temp below acceptable level Check EGR system, (Valve/VSV/Hose/Tem
post Nov 15, 2006 - 8:16 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I'll have to check the GT4 repair manuals when I get home but I'm pretty sure that the info in that link is correct if you scroll down to the 3rd gen stuff.
It may be a code 14 or it could be a 54. You need to double check your codes and make sure you're counting the flashes right. That is the only way we can help.
post Nov 15, 2006 - 2:20 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(WannabeGT4 @ Nov 15, 2006 - 5:16 AM) [snapback]502542[/snapback]
I would guess its code 54. It would allow the car to run in low-boost/safe mode. Code 14 would cause the car to stall and possibly not start (or only run for 1-2 seconds or so).
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Nov 15, 2006 - 2:46 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(phattyduck @ Nov 15, 2006 - 1:20 PM) [snapback]502615[/snapback]
-Charlie
Oh. I didn't realise it was running already. In that case I would bet that it is a code 54.
post Nov 16, 2006 - 2:17 PM
urbandork
Joined Jul 16, '04
From Los Angeles
i duno what i was smoking but i checked again and it was a 54 and not a 414 or 41 4 lol i guess i miss counted a few times
if i hadnt miss counted i would have knon exactly what to do lol
Lo-Fi Version Time is now: December 1st, 2024 - 2:38 AM
