> 365cc injector too big?
post Nov 21, 2006 - 11:42 PM
normality78
Joined Oct 27, '05
Finally, i went to dyno tuned my toyota corolla 7AFTE by using emanage blue. Found out i was running freaking rich whn offboost and I was being told my injector was too big for my setup as Im using 4AGZE 365cc injector. I've replaced stock map to 3bar Haltech map sensor.
dyno result showed 160whp with quite a few problem exists (not totally related with injector issue).
So may i have some gurus opinion on this. Issit 365cc injector was way too big for a 160whp setup car?
I do not have an adjustable fuel regulator to control. so i need one?
As i was being told, emanage will only take over the fuel control after 25% throttle load. As before, its still using stock ecu to control the fuel load. Can this be the reason why its running too rich?
seriously need help here....
post Nov 25, 2006 - 3:11 AM
Driveby
Joined Sep 17, '05
From Newcastle / UK
365cc injectors should be fine, its all down to the duty cycle signal given by the ecu. I dont know much about the emanage but it sounds more suited to the stock injectors for your motor if you dont have full duty cycle control with it. I run 800cc injectors controlled by an Apexi Power FC which has full injector control and is just fine.
1994 JDM GT4 WRC
post Nov 25, 2006 - 10:10 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Nuke nows what he's talking about. He already answered your question at celicatech:
http://www.celicatech.com/forums/showthread.php?t=21458
post Nov 25, 2006 - 11:15 AM
QUOTE(WannabeGT4 @ Nov 25, 2006 - 10:10 AM) [snapback]505166[/snapback]
X2
Lo-Fi Version Time is now: January 9th, 2025 - 10:44 PM
