> having tach problems need help!
post Nov 24, 2006 - 12:21 PM
JRB8
Joined Nov 2, '06
From va beach
wuts up, i just installed new custom gauges from speed hut and ever since i put them in my tach sticks. for example when i idle the needle sticks at 2k, also when i go to run all the way through 1st it will stick again at 3k jump to 5k stick there and wont come back down the guage faces are all the way on so the needle hitting that is out of the question. but im guessing there is a wire loose somewhere or a plug but im not shure so ne help would really be appreciated
post Nov 24, 2006 - 1:27 PM
95celicagt1987
Joined Aug 28, '06
From morristown
ur in luck i just put mine in and they did the same thing you need to take it all back apart and get some scotch 2 sided tape the thin kind like normal tape but with 2 sides oence you have that take the gauges off and put it on the factory face around the neadle on all 4 sides be sure not to get it under the neadel though
once you have done that then you are redy to put them back on when putting them on besure not to hit the tape withthe new face because it will get stuck. it will come off but with some diffaculty. i would sugest dooing it to all of them while you have it out just to be on the safe side
when you get it fixed post pics
Lo-Fi Version Time is now: November 29th, 2024 - 5:18 PM
