> Radiator need information!!, radiator install
post Nov 24, 2006 - 1:20 PM
monky32
Joined Oct 19, '04
From orlando
Hey guys!! i am trying to install my new radiator but it came with the golden and black little tubes so i don't know where they attach. any ideas?. i don't see those in my oem radiator.
This post has been edited by monky32: Nov 24, 2006 - 2:03 PM
post Nov 24, 2006 - 2:05 PM
Vissi
Joined Jun 6, '06
From Cedar Hill ,Texas
There for the automatic tranny, if u have a manual just cap them, (thats what my autotech teacher did to mine anyway). Its a totally separate chamber, I don't believe it will hurt anything.
0111011001101001011100110111001101101001
Chrome wont get ya home
post Nov 24, 2006 - 5:08 PM
QUOTE(Vissi @ Nov 24, 2006 - 2:05 PM) [snapback]505011[/snapback]
100% correct.
post Nov 24, 2006 - 9:48 PM
monky32
Joined Oct 19, '04
From orlando
Thanks guys!! that's what i was thinking so i'll find couple of caps or bolts. appreciate your help.
post Jul 28, 2009 - 7:03 PM
Jaws4God
Joined Mar 27, '04
yeah i had the same problem.. they came with 2 rubber black caps on them.. I guess I just live them on there and not worry about them.
here's a pic.. sorry its blurry.. from phone with low lighting..
This post has been edited by Jaws4God: Jul 28, 2009 - 10:39 PM
post Jul 28, 2009 - 7:12 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
If u had the time and the money, hook them up to the oil lines for cooling.
post Jul 29, 2009 - 10:22 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (Jaws4God @ Jul 28, 2009 - 5:03 PM) *
Just leave it like that, It would be fine! I have a 5spd and i replaced my rad last month. I was confused too at first. AT radiators are bigger and better cooling than the std.
QUOTE (soulshadow @ Jul 28, 2009 - 5:12 PM) *
Can you do this for a std tranny car?
God made man....
Everything else...
Made in China
post Jul 29, 2009 - 9:14 PM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
Really? That wouldn't contaminate your oil and deteriorate the detergents in your oil?
post Jul 29, 2009 - 9:51 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Its just like an oil cooler but instead its for your auto tranny fluid. Like I said its just "something" you could probbally do, but then again if you think about it.
The radiator gets hot and I am assuming that its for warming up your tranny fluid, or cooling it if it gets too hot. I dunno. Just cap it.
post Jul 29, 2009 - 10:19 PM
you can run any fluid through those lines, it will help keep that fluid at the same temp as the coolant. warm it or cool it, you can use it to cool the engine oil, or the very least keep it no hotter than the engine coolant.
post Jul 30, 2009 - 2:38 PM
Random_Stranger
Joined Mar 20, '07
QUOTE (Bitter @ Jul 29, 2009 - 8:19 PM) *
oh ok that makes sense then, so really it is just for fluid to go through that part of the radiator and just for that other fluid to flow through, right? I didn't know that, which is why I was asking. That's pretty cool then and very handy to know. I was thinking it would mix with the fluid, but then that wouldn't make much sense then, considering it is mostly used with an automatic.... So I see now.
This post has been edited by Random_Stranger: Jul 30, 2009 - 2:39 PM
post Jul 30, 2009 - 4:42 PM
trdproven
Joined Aug 2, '05
From Guam
the oil cooler is for cooling the ATF via the radiator. ATF needs more cooling than gear oil. Im using still my auto radiator for my std conversion. You do not even need caps or bolts for the metal tubes, all you do is get the hose used for the oil cooling and just loop it back from one side to the other for standard trannies.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 30, 2009 - 7:33 PM
i should mention that generally the automatic radiator has a slightly higher cooling capacity since it has to deal with the engine heat AND transmission heat.
post Aug 4, 2009 - 9:34 PM
mitch1911
Joined Jul 8, '09
From Missouri
When I pulled the two small black hoses off the back of mine, oil came out, not tranny fluid. Help me understand this, if those lines coming out of the front of the engine/tranny, going into the radiator are for cooling the ATF, why would it be oil in there. Obviously, the two larger black hoses take the anti-freeze throughout the block, but this is the first oil cooler built into the radiator that I have seen. I am putting a new one (actually recycled) in this weekend, so hopefully, those two extra ports are on there. I didn't ask the seller if they had an auto or std.
Lo-Fi Version Time is now: December 4th, 2024 - 8:49 PM
