> Another swap issue, Brakes not working correctly.
post Nov 25, 2006 - 12:13 PM
jcbass7
Joined Apr 20, '06
From Florida
ok so the swap is running and we have gotten her to drive, but the brakes are lacking ... they work only to the floor but barely... (ebrakes not on there right now, no pads or nothing at the moment.)
they are bled and have fluid in the res... my thoughts are.. maybe there is still air in the lines? the pedal does not pusle at all just is pretty weak to the floor and works barely....
any ideas?
post Nov 25, 2006 - 1:16 PM
are you sure you connected the brake booster vac line to the motor?
post Nov 25, 2006 - 1:58 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
What do you mean the ebrake's not on there at all right now?
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Nov 25, 2006 - 3:45 PM
jcbass7
Joined Apr 20, '06
From Florida
re-bled the brakes, they work a lot better now.. ill check the booster though too.
The e-brake pads are off completly since the pads are dead and so are the cables. I'm going to buy new ones from toyota
Lo-Fi Version Time is now: November 23rd, 2024 - 12:28 PM
