![]() Enthusiast ![]() Joined Apr 8, '03 From New York City Currently Offline Reputation: 0 (0%) ![]() |
Hi. Just a friendly warning to all that plugging a high drain appliance such as a power inverter into the cigarette lighter socket might render it inoperable!!!
OK, before somebody tells me that there is a fuse to protect the circuit and all that let me present my findings: 1. The fuse that protects the lighter socket is the same one that protects the radio. The radio works, the socket does not. So the fuse is not enough to protect the socket. 2. I use a meter to check the voltage of the cable plugged into the socket and there is 12 volts on the wire. So there is power, but none comes out of the socket. 3. Now check this picture out, there is clearly an element between the center contact and the post on the left that takes the +12 volt. I measured the conductivity of this element and there is none. Now this element is hidden under the rubber sleeve and I do not know what it is (but I do suspect it is a diode that protect the battery by preventing current flow to the opposite direction) but it is clearly blown! ![]() Anyway, I'm going to take this to the Toyota dealer and see what they have to say!! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) ![]() |
hmm... my cig lighter has never worked. didn't bother me too much since i don't smoke, but this is interesting. i wonder if the previous owner blew it.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) ![]() |
QUOTE(j0e_p3t @ Dec 14, 2006 - 9:50 PM) [snapback]510560[/snapback] hmm... my cig lighter has never worked. didn't bother me too much since i don't smoke, but this is interesting. i wonder if the previous owner blew it. I don't either. I use it to charge my phone when I forget to at home. I'm curious to know what that is too cuz I was contemplating on using that cigarette lighter as a hidden ignition switch as an added security. -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
that WAS a fusible link. it blows when theres a high draw, you can blow that AND the fuse if its some ungodly high amperage.
![]() Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) ![]() |
Just buy another, surely they aren't huge $$$
OK, ppl, I finally got it all sorted out!!!
First off, I did what I said I was gonna do which is to go to the dealer and get a new part. I was told I had to get the whole cigarette lighter assembly so I did. Thanks to this thread http://www.6gc.net/forums/index.php?showto...mp;#entry502818 I was able to remove the old lighter socket. Now here are the old socket and the new socket side by side, with the old one on the left: ![]() As you can see something's definitely wrong with the old one - the wire seems "exploded". I tried to remove the wire by pulling on the bulb with a pair of pliers but one end just broke right off. It felt like the only thing holding was the rubber sleeve. After I removed the sleeve form the middle here is what I found: ![]() The wire was just detached. Now there was no fuse, no diode, no anything, just an ordinary piece of wire.. I took a ohm reading with a multimeter and it conducted.. wtf??? Now because of the ease with which I broke the wire and how the wire seemed to give under the pliers I suspected that it is actually a piece of solder wire. Now the thing about solder is that it is metal but melts in relatively low temperature. To prove my suspicion I put a soldering gun to the wire and the voila the tip just melted!! Here you can see a small piece of the tip of the wire has gone to the soldering gun. ![]() So here is the answer. As to exactly what I hooked up to the lighter socket to run enough current to melt the wire.. I connected a laptop to a power inverter to the lighter socket. The laptop was on and the battery was drained. The total power drain to power the laptop and to charge the battery was about 80 watts. Well I guess it's time to go to Radio Shack and see what they have so next time it happens I don't have to replace the whole darn socket!!! |
![]() Enthusiast ![]() ![]() Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) ![]() |
Thanks for the Info
Enthusiast Joined Dec 26, '06 From West Covina, CA Currently Offline Reputation: 0 (0%) ![]() |
I got a 12V socket, not designed for heating the lighter, from Pep Poyz and will hard wire it into the battery with an in-line fuse so I can charge my cell or bluetooth with the ignition off. I'll mount it on the pass side of the center console to keep it out of the way when getting in the car. I got a basic one-socket type, but they have them with two and more sockets in one assembly and I'm sure some are for high power applications.
I don't care for the fact the lighter socket requires the ignition switch to be switched to on or acc. I'm sure it's a safety consideration from the design engineers. All other cars I have had let me light my smoke with no key in the switch, always hot. |
OK, guys, after some more extensive research I found out that this is a design intended to prevent a stuck cigarette lighter from causing a fire. The wire is called a fusible link and it "blows" at high temperture which of course has the side effect of doing the same under heavy current flow. A search of old news group posts…
http://groups.google.com/groups?hl=en&...sa=N&tab=wg Well I guess case closed!! ![]() This post has been edited by pflau: Jan 3, 2007 - 11:48 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
you should be some sort of CSI....your attention to detail borders monk... GOOD JOB! (Mine did the same thing a few years ago replaced the whole bloddy thing and now im getting contact problems with my RADAR DETECTOR.
.....I cant believe the guys that said they dont use theirs dont have a radar detector stuck in it then again, just because u got a 6gc dont mean u speed...like a maniac....and get tickets all the time.... ![]() ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jan 30, '06 From Augusta, GA Currently Offline Reputation: 4 (100%) ![]() |
When I bought my 98 Hatch, the cig lighter was all types of screwed up. Took it out only to find out that it looked as though it had burnt out and melted everything underneath. Bad times.
-Triscuit -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Lo-Fi Version | Time is now: February 16th, 2025 - 11:18 PM |
