is this everything i need to do the swap? |
Jul 8, 2003 - 2:48 PM |
Enthusiast Joined Jan 29, '03 From colorado Currently Offline Reputation: 0 (0%) |
i found a motor that comes with all of the stuff that i need it comes wwith all of the sensors this stuff
Block -Complete Head -Intake Manifold -Throttle Body -Top Engine Harness -Power Steering pump -Power Steering high pressure Line -Wastegate solenoid controller -Lower Engine/transmission harness -Turbo exhaust outlet extension -Turbo inlet pipe -Turbo outlet pipe -Wastegate actuator -Cam Angle Sensor -Bell housing bolts -Exhaust Manifold -Alternator -Starter -Fuel Rail -Injectors -Canister -Turbo -ECU (Computer) -5-Speed Transmission - With Clutch components assembled to the engine - Engine Wiring Harness (cut) - Intercooler is this most of the stuff i would need or is there more its a st205 engine |
Jul 8, 2003 - 9:56 PM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
you will probably need an uncut harness.
plus you will need the misc. nuts and bolts -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jul 8, 2003 - 11:52 PM |
Enthusiast Joined Nov 15, '02 From Corona & Vallejo, CA Currently Offline Reputation: 0 (0%) |
Add these to your list:
- Fuel Pump - Water Pump * - Timing Belt - Distributor cap * - Spark Plug Wires * - Spark Plugs - Cap & Rotor - NEW transmission (can't use the 205 tranny; you'll need either a Celica GT, MR2 Turbo, or Solara tranny) - Clutch * - Motor oil - Tranny fluid - Oil filter - Coolant - Axles * Maybe, depending on the condition of the parts that comes with the clip SIDE NOTES: The harness WILL need to be rewired from a RHD setup to a LHD setup. Talk to Qatar (Mike) on Celica.net or www.elprototypes.com. ELP tends to lag, so you may want to speak to Mike instead. Also, the GT tranny (S-53) isn't as strong as the MR2 Turbo / Solara trannies (E-153). There may be more, but I just can't think right now... This post has been edited by kuya1284: Jul 9, 2003 - 6:15 AM |
Jul 10, 2003 - 11:57 AM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
You'll need all 4 motor mounts and gt shift linkage. If you have a GT you should have both of these. Also some extra radiator hose.
Jul 10, 2003 - 12:22 PM |
He has a GT, which is why I didn't mention the mounts... |
Jul 10, 2003 - 10:15 PM |
MR2 tranny case change? Possibly?
Lo-Fi Version | Time is now: November 25th, 2024 - 11:36 AM |
