> whould a 7gen trany
post Jan 24, 2007 - 1:06 AM
junost4
Joined Aug 15, '06
From moreno valley
whould the gts trany from a 7th gen gts fit on a 6gen celica 3sgte
post Jan 24, 2007 - 1:24 AM
BLADDER_MASTER
Joined Dec 8, '04
This post has been edited by BLADDER_MASTER: Nov 13, 2012 - 2:47 PM
post Jan 24, 2007 - 1:35 AM
no, it would not.
post Jan 24, 2007 - 2:23 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(junost4 @ Jan 23, 2007 - 10:06 PM) [snapback]520717[/snapback]
would not fit.
beside the 7th gen transmission is not very strong at all. I'm assume it would break from all the torque the 3s would put out.
post Jan 24, 2007 - 10:15 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
from what ive heard, it wont work with the 3S. But if you put on the C52 bellhousing it would fit on the 7A. I may be wrong tho
-Brian
post Jan 25, 2007 - 2:34 AM
quicknstyle
Joined Oct 3, '02
From HOUSTON
why are we saying whould???
post Jan 25, 2007 - 3:12 AM
BLADDER_MASTER
Joined Dec 8, '04
post Jan 25, 2007 - 10:12 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(quicknstyle @ Jan 24, 2007 - 11:34 PM) [snapback]521112[/snapback]
because if we use the words "CAN NOT fit" then it is stronger and can be proven wrong. When we say would we are leaving part of the argument in the air so if some day someone decides to pay alot of cash to MAKE it fit. Then we are not wrong.
But for your average joe, the 7th gen gts transmission does not have interchangable parts that would allow it to bolt up to the 3s easily. Therefore it "would" not fit. The gearing is wrong for a turbocharged engine and the torque curve does not match up to the N/A torque curve of the 7th gen engine. An example of what this means is: every time you shift you drop out of the power-band and go through the turbo lag agian. Although this example is not true; it does give you an idea of how bad transmission matching with a good engine can make a car slower.
*edit for grammer*
This post has been edited by Hanyo: Jan 25, 2007 - 10:19 AM
post Jan 25, 2007 - 12:11 PM
Kadett
Joined Mar 17, '05
From The Netherlands
7th gen tranny is very weak. And would not sustain the power of a 3s for long.
Heard of some turbo 7th gens with a LSD and drag tyres destroying the tranny after a few 1/4 runs.
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 22nd, 2024 - 9:37 PM
