> What do think about those brake discs..., Good enough for ST?
post Jan 29, 2007 - 3:14 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I have found those brake discs are available also for ST celicas. What do you think about them? Anyone using them?
Brembo MAX
thanks for opinion.
p.s.: picture is not exactly perfect... (not those for ST celica). For ST celica are:
Front Axle diameter 255 mm
Pitch Circle diameter 55 mm
Thickness 25 mm
Num. of holes 5 with General Certification (ABE)
This post has been edited by malpaso: Jan 29, 2007 - 3:21 AM
post Jan 29, 2007 - 3:14 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
I think those look most like the rotors they use for the tarmac rallies in the WRC than anything else I've seen available for road cars.
[depending on cost] I'd try them, they might make some noise though kindasad.gif
I <3 Dustin---07/16/06
post Jan 29, 2007 - 6:23 PM
brembo makes good rotors, give them a try.
post Jan 30, 2007 - 2:18 AM
malpaso
Joined Feb 3, '06
price is $170 for pair...
post Jan 30, 2007 - 3:08 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
QUOTE(malpaso @ Jan 30, 2007 - 12:18 AM) [snapback]522555[/snapback]
Not too bad for a 170$ - just DONT get the Drilled ones - they are crap. Aim for the slotted rotors at most.
<<<<<< DCw / JDMart >>>>>>>
post Jan 30, 2007 - 8:42 AM
spolski07
Joined Jul 7, '06
From Los Alamos, NM
off topic... but why does that wrx only have 4 lugs?
post Jan 30, 2007 - 12:27 PM
WH95TE
Joined Jun 16, '06
From Plantation, FL
I need to get some disc breaks in the back
post Jan 30, 2007 - 1:14 PM
Diab1o_3000
Joined Jul 14, '06
From Jonesboro, GA
What's wrong with drilled rotors? I was considering getting drilled and slotted rotors this summer or spring break. Please stop me before I make a mistake!!!
I'm not trying to jack the thread, but I'm just curious.
This post has been edited by Diab1o_3000: Jan 30, 2007 - 1:15 PM
post Jan 30, 2007 - 2:08 PM
QUOTE(Diab1o_3000 @ Jan 30, 2007 - 1:14 PM) [snapback]522654[/snapback]
drilled rotors, even when correctly made, have a much greater tendency to crack. 100% of the cheap cross drills out there are incorrectly made.
post Jan 31, 2007 - 12:48 PM
brthrurik
Joined Mar 24, '06
From Aloha, Oregon
[/quote]
[/quote]
x2 even the good ones aren't correctly treated after drilling, and the ones that are run about 600$ a pair
Lo-Fi Version Time is now: February 18th, 2025 - 4:32 AM
