> Brakes?, supra brakes
post Feb 9, 2007 - 12:47 AM
Kerr1
Joined Dec 24, '06
From jonesville
i know this is a stupid question....but u know how 240s can convert their calipers to the 300zx well i was wonderin if anyone has researched supra brakes and if they fit GTs...sry if its a stupid question was kinda hopin it would wrk tho..and i dont know that much abt. brakes so any advice would b great.
post Feb 12, 2007 - 2:33 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
You should try & see!!!
post Feb 12, 2007 - 6:55 AM
Gmoney1
Joined Feb 9, '07
From St.lucia
well from wat i kno is that the supra's carry a different hole pattern on their rims ... so if u goin to try to upgrade ur braking system to the supra's u will need to change the whole thing , and when i mean the whole thing i jus means the studs and discs , calipers and watever else u need to change.
post Feb 12, 2007 - 9:27 AM
rofl try the 2jz swap while you're at it!!!
0k no seriously, the supra brakes arn't going to fit, you don't have rotors that are large enough and correctly spaced, and i doubt the caliper would even bolt up without some form of spacer and adaptor
post Feb 12, 2007 - 9:32 AM
celicaST
Joined Jun 23, '05
QUOTE(playr158 @ Feb 12, 2007 - 7:27 AM) [snapback]526126[/snapback]
for some reason i thought the mkiv supra shared the same brakes with the gt four
post Feb 12, 2007 - 12:42 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
This post has been edited by 95CelicaST: Feb 12, 2007 - 12:42 PM
**** Photobucket
post Feb 12, 2007 - 1:59 PM
QUOTE(95CelicaST @ Feb 12, 2007 - 12:42 PM) [snapback]526169[/snapback]
post Feb 12, 2007 - 2:01 PM
95CelicaST
Joined Feb 5, '05
QUOTE(playr158 @ Feb 12, 2007 - 10:59 AM) [snapback]526184[/snapback]
Thank you, Thank you.
**** Photobucket
post Feb 12, 2007 - 5:12 PM
celicaST
Joined Jun 23, '05
QUOTE(95CelicaST @ Feb 12, 2007 - 12:01 PM) [snapback]526185[/snapback]
i never said that gt four brakes fit smart ass. just pointing out that they should have the same hole pattern in response to gmoney1's reply.
post Feb 12, 2007 - 5:26 PM
QUOTE(celicaST @ Feb 12, 2007 - 5:12 PM) [snapback]526246[/snapback]
you quoted and replied to my post? and you NEVER mentioned a hole pattern in your own reply..
but why woulda GT4 have the same hole pattern as a supra?
since the GT4 has the same pattern as a normal celica...
i guess what we are saying here is where are you relating a celica and a supra besides the fact they are both made by toyota laugh.gif
This post has been edited by playr158: Feb 12, 2007 - 5:26 PM
post Feb 12, 2007 - 6:23 PM
celicaST
Joined Jun 23, '05
QUOTE(playr158 @ Feb 12, 2007 - 3:26 PM) [snapback]526250[/snapback]
fair enough, dont be a prick, im not familar with brakes. i just figured that if the supra and gt four did share the same brakes as ive heard, then they would have the same hole pattern, and it would be possible to put the supra brakes (i assume you would need to swap to superstrut however)
post Feb 12, 2007 - 7:06 PM
so if i'm a prick does that make you ignorant?
cause Supra = Mcpherson suspension....
This post has been edited by playr158: Feb 12, 2007 - 7:06 PM
post Feb 12, 2007 - 7:12 PM
95CelicaST
Joined Feb 5, '05
This post has been edited by 95CelicaST: Feb 12, 2007 - 7:14 PM
**** Photobucket
post Feb 12, 2007 - 9:48 PM
GTSOwner
Joined Sep 28, '06
From Montreal, QC, Canada
-you don't have the weight of a supra
-you don't have the power of a supra
Therefore, you don't need the brakes of a supra
-you don't have the same master cylinder
-you don't have the same proportioning valve
-you don't have the same bolt pattern
-you don't have the same mounting points for the calipers
Therefore, the brakes off of a supra do not fit
Seriously, put on some good disks (brembo blanks) and good pads (Hawk HPS, HP+, Porterfields). They'll be bolt-on and will brake nearly, if not as good as... you guessed it : a supra.
post Feb 12, 2007 - 10:49 PM
Kerr1
Joined Dec 24, '06
From jonesville
thanx....i just dont wanna go flying off a mountain cuz my brakes arent strong enough....i wont to b able to brake way later then what im doin now. Thats all i want....i was just tryin to find a cheeper way of getting good calipers.
post Feb 12, 2007 - 11:02 PM
Calipers you have right now are way more then sufficient
you just need good pads and rotors coupled with some decent tires!
BBK = just for show on the street
This post has been edited by playr158: Feb 12, 2007 - 11:02 PM
post Feb 12, 2007 - 11:13 PM
Kerr1
Joined Dec 24, '06
From jonesville
yea...i know i need new rotors and pads...wats tha recomendation on rotors? thinkin abt. goin w/ slotted...i heard drilled rotors crack w/ excesive heat.
post Feb 13, 2007 - 1:02 AM
trdproven
Joined Aug 2, '05
From Guam
Well, just to jump in here. Overall, if you change the necessary parts can you still convert it?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 13, 2007 - 7:31 AM
GTSOwner
Joined Sep 28, '06
QUOTE(Kerr1 @ Feb 12, 2007 - 11:13 PM) [snapback]526322[/snapback]
QUOTE(GTSOwner @ Feb 12, 2007 - 9:48 PM) [snapback]526292[/snapback]
You can also go with the iRotors slotted stuff which I hear is pretty good.
post Feb 14, 2007 - 11:12 PM
jdg371
Joined Jun 14, '05
no real need for drilled/slotted unless your hard on your brakes for hours.. get some HP plus pads, Brembo replacement rotors, new brake fluids.. and maybe some braided brake lines.. you should be set..
Lo-Fi Version Time is now: January 12th, 2025 - 9:55 PM
