> Pod Filter Installation Question
post Feb 28, 2007 - 5:58 PM
AussieBoy
Joined Apr 21, '06
From Australia
Hi Guys, I've ordered a new pod filter for my celi, and i'd just like som points on what to do with the"Air intake temp sensor" that fits into the top of the old filter box. Will pulling this off cause a "Check engine light"? Also where is the best place to run Cold intake from.
Cheers
post Feb 28, 2007 - 10:52 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Well I ran my cold air from the fender. My intake comes from the fender under the battery up over the transmission and up to the intake manifold. I don't know if that is the best but it helped my car out. I also drilled a hole in the tube and lined it with rubber (short piece of vacuum line cut down one side) and stuck the intake air temp sensor there.
Lo-Fi Version Time is now: November 27th, 2024 - 10:33 PM
