Spacers, 7th gen GTS rims |
Mar 3, 2007 - 11:26 PM |
Enthusiast Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
This is a thread for those how have had first hand experience with spacing out GTS rims. Wondering what you're using SIZE wise, and what you would recommend SIZE wise to make a flush, but functional setup with 50/55 tires (sidewall).
H&R spacers of course… My current thought would be 5mm spacers, but would like to hear from people that have had first hand experience. Please post pictures if possible. Thanks- -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Mar 3, 2007 - 11:33 PM |
Enthusiast Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
QUOTE(snapshotgt @ Mar 3, 2007 - 11:26 PM) [snapback]532599[/snapback] This is a thread for those how have had first hand experience with spacing out GTS rims. Wondering what you're using SIZE wise, and what you would recommend SIZE wise to make a flush, but functional setup with 50/55 tires (sidewall). H&R spacers of course… My current thought would be 5mm spacers, but would like to hear from people that have had first hand experience. Please post pictures if possible. Thanks- I made my own 1/4" spacer.. using 225/55/16's .. 7th gen rims of course.. 1/4" is a cunt hair over 6mm. A thicker spacer would be nicer though.. I'd say more like 1/2" .. however, 1/4" is nice.. plus you don't need to do anything with the studs. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Mar 4, 2007 - 1:24 AM |
No matter what size i go with, i will be buying H&R spacers --> don't want to screw around with something so crucial.
GTS rims are 39mm offset correct? -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Mar 4, 2007 - 3:00 AM |
QUOTE(snapshotgt @ Mar 4, 2007 - 1:24 AM) [snapback]532630[/snapback] No matter what size i go with, i will be buying H&R spacers --> don't want to screw around with something so crucial. GTS rims are 39mm offset correct? What do you mean something so crucial? You do realize that a 1/4" spacer does not require anything to be done with the lugs right? The only thing a 1/4" spacer will be is a round piece of machined steel or aluminum and 5 holes drilled in it... I don't care what brand you go with.. it's not like I'm selling them.. Just want ya to know that a spacer that thin is nothing special at all. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Mar 4, 2007 - 2:13 PM |
H&R spacers are hubcentric, precision engineered, and have unrivaled fit.
Mar 4, 2007 - 4:48 PM |
there was a guy on here with a white celica that had 7th gen rims with spacers that looked really good. i think he was using a 15 or 25m spacer. try searching the members profiles.
i wouldnt bother with a 5m. it wont make much of a difference, and like punisher said, with a sparer that small, it really doesn't matter much what you use. even pepboys stocks 5m spacers. but if you go with a 15 or 25m, thats when you really want a quality spacer. This post has been edited by lagos: Mar 4, 2007 - 4:48 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 4, 2007 - 11:01 PM |
Enthusiast Joined Apr 2, '06 From Socal Currently Offline Reputation: 0 (0%) |
you would have to re-torque spacers every 100-200 miles or so.
Mar 5, 2007 - 12:29 AM |
I've driven ~2,000 or more miles with 16mm spaced in the rear , 5mm spaced in the front.....i've never retorque....and its the same
Mar 5, 2007 - 1:20 AM |
Enthusiast Joined Apr 16, '05 From Orlando, FL Currently Offline Reputation: 1 (100%) |
QUOTE(playr158 @ Mar 5, 2007 - 12:29 AM) [snapback]532908[/snapback] I've driven ~2,000 or more miles with 16mm spaced in the rear , 5mm spaced in the front.....i've never retorque....and its the same X 2 ..ive had spacers since december 06'..driven 3,000+ since, and have never had to re-torque my spacers -------------------- |
Mar 5, 2007 - 2:05 AM |
i guess you guys dont take it to the track
Mar 5, 2007 - 2:12 AM |
ok back on topic
what size spacers are ideal for 7th gen 16" GTS wheels ? -------------------- |
Mar 5, 2007 - 2:21 AM |
the wheels are 6.5 wide and have a 39mm offset with 205/50/16 tires.
Mar 5, 2007 - 2:38 AM |
Enthusiast Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
QUOTE(Batman722 @ Mar 5, 2007 - 12:21 AM) [snapback]532933[/snapback] the wheels are 6.5 wide and have a 39mm offset with 205/50/16 tires. http://www.6gc.net/forums/index.php?showtopic=32534 according to that, (6.5/2)*25.4-(39-x)=74, would need a 30mm spacer for standard ride (6.5/2)*25.4-(39-x)=63, would need a 20mm spacer for lowered ride -------------------- I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Mar 5, 2007 - 2:45 AM |
QUOTE(snapshotgt @ Mar 4, 2007 - 2:13 PM) [snapback]532740[/snapback] H&R spacers are hubcentric, precision engineered, and have unrivaled fit. Did you get that little bit from their website? Good luck finding a hubcentric 5mm spacer. The "ideal" spacer really depends on what look you are going for.. and also tire size. a 5mm spacer will clear 225/55/16 in the rear.. nothing larger. The front doesn't need a spacer for that size. -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Mar 7, 2007 - 10:48 AM |
QUOTE(celicaST @ Mar 5, 2007 - 2:38 AM) [snapback]532939[/snapback] QUOTE(Batman722 @ Mar 5, 2007 - 12:21 AM) [snapback]532933[/snapback] the wheels are 6.5 wide and have a 39mm offset with 205/50/16 tires. http://www.6gc.net/forums/index.php?showtopic=32534 according to that, (6.5/2)*25.4-(39-x)=74, would need a 30mm spacer for standard ride (6.5/2)*25.4-(39-x)=63, would need a 20mm spacer for lowered ride thanks yeah I saw that. So 15mm spacers should be more than acceptable, just not out as far as the 20mm. OK. -------------------- |
Mar 9, 2007 - 2:56 PM |
Enthusiast Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Okay.. question... not to hijack or anything, but my 17X7 rims have an offset of +42. I want to at least get the rear more flush, so which size spacer should I look into?
I'm not really an asshole, but I play one on the internet. **** Photobucket |
Mar 9, 2007 - 4:17 PM |
QUOTE(95CelicaST @ Mar 9, 2007 - 12:56 PM) [snapback]534753[/snapback] Okay.. question... not to hijack or anything, but my 17X7 rims have an offset of +42. I want to at least get the rear more flush, so which size spacer should I look into? (7/2)*25.4-(42-x)=63, x=16.1, so i would get a 15mm spacer -------------------- I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Mar 9, 2007 - 5:26 PM |
Enthusiast Joined Nov 21, '05 From Wpg, MB. Canada Currently Offline Reputation: 3 (100%) |
Do we even actually NEED the spacers? Or did you want them just for the flush look?
I run 16" 7th gen gts rims with the standard tire (205/50/16?). QUOTE(snapshotgt @ Mar 3, 2007 - 11:26 PM) [snapback]532599[/snapback] This is a thread for those how have had first hand experience with spacing out GTS rims. Wondering what you're using SIZE wise, and what you would recommend SIZE wise to make a flush, but functional setup with 50/55 tires (sidewall). H&R spacers of course… My current thought would be 5mm spacers, but would like to hear from people that have had first hand experience. Please post pictures if possible. Thanks- |
Mar 9, 2007 - 6:01 PM |
Enthusiast Joined Jun 28, '05 From MB, Canada Currently Offline Reputation: 1 (100%) |
spacers are just for the flush look.
I have 7th gen rims with 205/50/R16's And... I have Ichiban 15mm spacers up front and 20mm spacers in the back, they are installed and look a little sunk with my stock 14" wheels. But it should look almost exactly flush on my lowered car. I dont know yet though because, as i said, im on 14" winter stealies right now This post has been edited by Tech9ine: Mar 9, 2007 - 6:03 PM |
Lo-Fi Version | Time is now: January 11th, 2025 - 5:15 PM |
