Enthusiast ![]() ![]() ![]() Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) ![]() |
hey guys...i was just wondering what the stock psi is set at for a ct26...ive heard its at 7, but then ive also read somewhere that its in the 5psi range. does anyone know for sure?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) ![]() |
the stock wastegate is set at 7
This post has been edited by shin: Apr 4, 2007 - 10:18 AM -------------------- |
thanks alot
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
On the Celica/MR2 it's ~ 8PSI [sometimes a bit more]. 7 Is actually a bit low.
For the Supra it's ~ 5-6 PSI. -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 10, '03 From Connecticut Currently Offline Reputation: 11 (100%) ![]() |
Also depends on your sea level. Mine was 8-8.5.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) ![]() |
so, does this mean that if you put a CT-26 on a 5sfte set-up (the turbo will be coming from a mr2 or alltrac) and don't use any kind of boost controller that you'll boost 7-8 PSI?
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
No. Other variables control boost also, like exhaust for instance.
This post has been edited by Supersprynt: Apr 4, 2007 - 9:26 PM -------------------- |
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) ![]() |
Depends... my stock 93 mr2 ran 12psi stock....put a full exhaust on it and it will get up to 16psi in 4th-5th gear
This post has been edited by bufferdan: Apr 5, 2007 - 12:07 PM -------------------- ![]() |
QUOTE(bufferdan @ Apr 5, 2007 - 1:06 PM) [snapback]543478[/snapback] Depends... my stock 93 mr2 ran 12psi stock....put a full exhaust on it and it will get up to 16psi in 4th-5th gear ct26 waste gate spring is set to 7psi. on the 3sgte normal boost is around 10psi, because of the factory boost control (tvsv). but if you get a bigger exhaust, youll have a harder time keep the boost that low. -------------------- 15PSI - 30MPG - Megasquirt Tuned
so, if I use a boost controller will I be able to keep my boost lower than just depending on the stock wastegate?
honestly, I wouldn't mind boost 10-11 PSI, I just don't know how much my motor will be able to take and I want to take it as easy as possible on it for the first few weeks. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Enthusiast ![]() Joined May 10, '06 From Somerset Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(6strngs @ Apr 5, 2007 - 3:39 PM) [snapback]543578[/snapback] so, if I use a boost controller will I be able to keep my boost lower than just depending on the stock wastegate? honestly, I wouldn't mind boost 10-11 PSI, I just don't know how much my motor will be able to take and I want to take it as easy as possible on it for the first few weeks. u cannot lower stock wastegate psi with a mbc. u can only raise it. to lower stock psi you would have to run an external wastegate and that can get pricey. -------------------- ![]() |
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) ![]() |
QUOTE(6strngs @ Apr 5, 2007 - 3:39 PM) [snapback]543578[/snapback] so, if I use a boost controller will I be able to keep my boost lower than just depending on the stock wastegate? honestly, I wouldn't mind boost 10-11 PSI, I just don't know how much my motor will be able to take and I want to take it as easy as possible on it for the first few weeks. If you got a mbc that works well, You could keep it at 5 psi. Thats very safe for that engine. 5 psi is how high it will boost when cold or when it sences a problem |
QUOTE(toyotacrazy @ Apr 5, 2007 - 8:44 PM) [snapback]543672[/snapback] QUOTE(6strngs @ Apr 5, 2007 - 3:39 PM) [snapback]543578[/snapback] so, if I use a boost controller will I be able to keep my boost lower than just depending on the stock wastegate? honestly, I wouldn't mind boost 10-11 PSI, I just don't know how much my motor will be able to take and I want to take it as easy as possible on it for the first few weeks. If you got a mbc that works well, You could keep it at 5 psi. Thats very safe for that engine. 5 psi is how high it will boost when cold or when it sences a problem this is NOT true. guys, this is simple. the wastegate on the ct-26 opens @ ~7-8psi. with a free fowing exhaust, it will creep. a boost controller will only allow you to RAISE, not lower boost. -------------------- Former Team 5SFTE pro member ;)
Exactly
And the TVSV can only raise boost from what the WG is set at. It can't lower it. -------------------- ![]() |
QUOTE(alltracman78 @ Apr 5, 2007 - 7:57 PM) [snapback]543676[/snapback] Exactly And the TVSV can only raise boost from what the WG is set at. It can't lower it. sorry, I havent experimented with my mbc since it doesnt currently work. Ok, so if you use the tvsv and either turn it on or off, manually, then you would stay at 5 psi. |
ok. I think I understand now. and I think I can scratch the MBC off the list of things I need for my 5sfte. at least for the time being.
QUOTE(toyotacrazy @ Apr 5, 2007 - 8:53 PM) [snapback]543703[/snapback] QUOTE(alltracman78 @ Apr 5, 2007 - 7:57 PM) [snapback]543676[/snapback] Exactly And the TVSV can only raise boost from what the WG is set at. It can't lower it. sorry, I havent experimented with my mbc since it doesnt currently work. Ok, so if you use the tvsv and either turn it on or off, manually, then you would stay at 5 psi. If your WG actuator is set for 8 PSI, you can't go below that, period. -------------------- ![]() |
QUOTE(alltracman78 @ Apr 6, 2007 - 12:27 PM) [snapback]543991[/snapback] QUOTE(toyotacrazy @ Apr 5, 2007 - 8:53 PM) [snapback]543703[/snapback] QUOTE(alltracman78 @ Apr 5, 2007 - 7:57 PM) [snapback]543676[/snapback] Exactly And the TVSV can only raise boost from what the WG is set at. It can't lower it. sorry, I havent experimented with my mbc since it doesnt currently work. Ok, so if you use the tvsv and either turn it on or off, manually, then you would stay at 5 psi. If your WG actuator is set for 8 PSI, you can't go below that, period. You CAN boost below 8 psi. when the tvis is activated it wont allow the car to boost past 5 psi. This is called SAFE mode. As ive heard it called. When the engine detects knock or cold temperature of the coolant temp. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(toyotacrazy @ Apr 6, 2007 - 5:51 PM) [snapback]544097[/snapback] QUOTE(alltracman78 @ Apr 6, 2007 - 12:27 PM) [snapback]543991[/snapback] QUOTE(toyotacrazy @ Apr 5, 2007 - 8:53 PM) [snapback]543703[/snapback] QUOTE(alltracman78 @ Apr 5, 2007 - 7:57 PM) [snapback]543676[/snapback] Exactly And the TVSV can only raise boost from what the WG is set at. It can't lower it. sorry, I havent experimented with my mbc since it doesnt currently work. Ok, so if you use the tvsv and either turn it on or off, manually, then you would stay at 5 psi. If your WG actuator is set for 8 PSI, you can't go below that, period. You CAN boost below 8 psi. when the tvis is activated it wont allow the car to boost past 5 psi. This is called SAFE mode. As ive heard it called. When the engine detects knock or cold temperature of the coolant temp. Your a little confused. its ok though. OK whatever the WG is set to is the lowest possible boost you can run. when "safe mode" activates it turns off the stock boost controller TVSV and you run W/e the WG spring is. when "safe mode" isn't on, normal driving conditions it bleeds off air so the actuator opens later, thus upping boost. i suck at explaining things. -------------------- |
QUOTE(toyotacrazy @ Apr 6, 2007 - 5:51 PM) [snapback]544097[/snapback] QUOTE(alltracman78 @ Apr 6, 2007 - 12:27 PM) [snapback]543991[/snapback] QUOTE(toyotacrazy @ Apr 5, 2007 - 8:53 PM) [snapback]543703[/snapback] QUOTE(alltracman78 @ Apr 5, 2007 - 7:57 PM) [snapback]543676[/snapback] Exactly And the TVSV can only raise boost from what the WG is set at. It can't lower it. sorry, I havent experimented with my mbc since it doesnt currently work. Ok, so if you use the tvsv and either turn it on or off, manually, then you would stay at 5 psi. If your WG actuator is set for 8 PSI, you can't go below that, period. to reitterate what ive been saying all along, the STOCK WASTEGATE SETTING IS ~7-8PSI You CAN boost below 8 psi. when the tvis is activated it wont allow the car to boost past 5 psi. This is called SAFE mode. As ive heard it called. When the engine detects knock or cold temperature of the coolant temp. trust me, jermey will know how the ct-26 actuator works better than you, hes a toyota tech. lol besides the fact that he has one TATTOOED onto his arm!! you have the right idea, just the wrong numbers. on a 3sgte, in "safe mode" IS 7-8psi. when the TVSV energizes, it goes up to ~10-11.8psi. -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: February 23rd, 2025 - 2:23 AM |
