> engine losing coolant, oh snap!
post Apr 6, 2007 - 2:45 PM
celicamike
Joined Dec 26, '05
From So Cal
Hey guys, my car has been losing coolant steadily for a few weeks now. There are no visible leaks, so it seems that I have a leaky head gasket. What do you guys think? can you recommend any of those radiator and block leak stop remedies from the auto parts store? I'd like to know what I should do about this, apart from telling people I have a "custom water injection".
This post has been edited by celicamike: Apr 6, 2007 - 2:49 PM
post Apr 6, 2007 - 2:55 PM
alltracman78
Joined Aug 9, '06
From Ma
Don't assume it's a HG and act accordingly.
Verify and THEN act.....
Don't use any of the stopleak stuff unless it's a temp fix.
And once you fix, get a GOOD [not Prestone from Walmart] coolant flush to get all the crap out.
Hit up autocrap and see if they have coolant pressure testers to rent for free.
If so, rent one and use it.
post Apr 9, 2007 - 2:49 PM
celicamike
Joined Dec 26, '05
From So Cal
OK, i put some alumaseal in with the coolant and now everything seems fine. Is there anything else I should do? can I just leave it the way it is now?
post Apr 9, 2007 - 2:54 PM
celicamike
Joined Dec 26, '05
From So Cal
sorry, double post.
This post has been edited by celicamike: Apr 9, 2007 - 2:57 PM
post Apr 11, 2007 - 8:25 AM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(alltracman78 @ Apr 6, 2007 - 2:55 PM) [snapback]544069[/snapback]
Werd
This post has been edited by Gary: Apr 11, 2007 - 8:25 AM
_Gary
post Apr 14, 2007 - 7:09 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
You should be able to see where the coolant leaks out if it is an external leak - it goes pink-white (if you're using the Toyota Forlife red coolant) or looks like a brown surface rust (if you're using green coolant).
If it's a headgasket you will get some vapours and your engine oil will have a layer of sludge on top of it, it's hard to explain but you'll see it if you have it. Conversely you will have a milky layer of oil in your coolant when you open the radiator cap.
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Apr 14, 2007 - 7:10 PM
hellsyphon
Joined Dec 3, '04
From torrance, ca
You better get that fixed soon or that stop leak is going to clog water jackets and whatnot in your engine...
Lo-Fi Version Time is now: December 4th, 2024 - 7:37 PM
