> Staggered wheel setups...can we run em???
post Apr 7, 2007 - 11:46 PM
Davesceli
Joined Apr 24, '04
From S. Cali
I've seen a couple 7th gen celis running staggered wheel setups and was curious what are the pros and cons of using that setup...i think it looks pretty sweet and i think it will look awesome on our 6th gens.
post Apr 8, 2007 - 2:42 AM
Hanyo
Joined Aug 16, '03
From Bay area
the only pro to the set up is: it looks good.
the cons:
inable to properly rotate tires.
increase understeer.
post Apr 8, 2007 - 4:44 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
If you use the same size tire all around, you can still rotate them. Just makes it more work for tire techs because they have to dismount tires, rotate tires (not wheels), and balance.
FlickR
post Apr 8, 2007 - 4:51 PM
Culpable04
Joined Apr 17, '06
From New Jersey
CAUTION !!
NEWBIE question !
what are Staggered wheels ?
post Apr 8, 2007 - 5:05 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(Culpable04 @ Apr 8, 2007 - 2:51 PM) [snapback]544553[/snapback]
CAUTION !!
NEWBIE question !
A staggered set up is basically when you have larger or wider wheels in the back than in the front. A staggered set up would be like 18x8.5 in the front and 18x9.5 in the back. The new Lexus IS350 comes with a staggered set up wink.gif .
post Apr 8, 2007 - 5:19 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(MaskedMan @ Apr 8, 2007 - 5:05 PM) [snapback]544559[/snapback]
CAUTION !!
NEWBIE question !
ahhhhhhhhh ok.
thanks
post Apr 8, 2007 - 6:02 PM
BLINKYxMUNKEY
Joined Nov 12, '03
QUOTE(Culpable04 @ Apr 8, 2007 - 5:19 PM) [snapback]544560[/snapback]
CAUTION !!
NEWBIE question !
ahhhhhhhhh ok.
thanks
If I remember correctly someone is building a car on here with a staggered set of wheels.
http://www.6gc.net/forums/index.php?showtopic=45285
FlickR
post Apr 12, 2007 - 10:16 AM
baddisintegra
Joined Nov 29, '06
From South Florida
i run 18x7.5 and 18x9.5 without much issue....u can feel the undertseer somewhat but unless you track your car, its no major issue
btw the look is bad-asssssss
Lo-Fi Version Time is now: December 4th, 2024 - 4:41 AM
