> st185 exhaust manifold, manifold swap
post Apr 18, 2007 - 2:27 PM
yozef
Joined May 24, '05
From Malta
quick question, will an st185 manifold fit an a leter gen 3s-gte?
post Apr 18, 2007 - 2:41 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Not 3rd or 4th gen. i believe it will fit 2nd tho.
post Apr 18, 2007 - 2:46 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
st185 is gen2. so no, it wont fit later gens.
post Apr 18, 2007 - 2:47 PM
Negative
Joined Apr 28, '04
From Houston, Texas
post Apr 18, 2007 - 2:48 PM
Gary
Joined Aug 28, '04
From FLA USA
Exhaust manifold comparison:
_Gary
post Apr 18, 2007 - 3:31 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
It seems to me like all the bolt patterns are different. If this is the case, how will any of the 3sgte manifolds fit the 5sfe?
94 Celica gt white (sold)
post Apr 18, 2007 - 3:54 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
1st might? looks like it. 2nd gen manifolds do.
This post has been edited by x_itchy_b_x: Apr 18, 2007 - 3:55 PM
post Apr 18, 2007 - 4:41 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Actually the 1st gen one is the same as the 5S but both versions of 2nd gen will fit [9 bolt requires some grinding]. If you look it appears that all of them will fit but some of the bolts can't be used and you will probably have to grind down the extra bolt hole areas at either end of the manifold. Not sure but that's what it looks like. I think only the 2nd gen one is a direct bolt up.
post Apr 18, 2007 - 5:27 PM
Gary
Joined Aug 28, '04
From FLA USA
Be aware that the 1st gen manifold is a single entry type.
You won't be able to use twin-entry CT26 on it.
However, a Supra CT26 or ST165 CT26 will bolt on.
These turbos have different downpipe bolt pattern from twin entry CT26 and CT20B.
You cannot use the downpipe that is made for twin-entry CT26 and CT20B.
Also, IIRC, 1st gen manifold will place the turbo in a little different location.
You might need to adjust the DP accordingly.
This post has been edited by Gary: Apr 18, 2007 - 5:28 PM
_Gary
post Apr 18, 2007 - 6:05 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Thanks for the info guys, I always thought that the st165 manifolds won't fit at all or something.
post Apr 19, 2007 - 10:19 PM
6strngs
Joined May 12, '06
From Wilmington, NC
2nd gen 7-bolt bolts up. I think the 9-bolt will go on too, I don't think there is anything in the way that would require the grinding of the extra two bolt holes, so you'll just have two holes that do nothing.
from the looks, 1st gen manifold might bolt up to a 5s too..
Lo-Fi Version Time is now: December 1st, 2024 - 10:10 PM
