> Starter just clicks...
post May 1, 2007 - 10:26 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I've had a recent problem with my starter lately that keeps getting worse. My car will just click over whenever I try to start it, sometimes it takes 20 clicks to get it to fire. I was thinking my starter or the solenoid is going out? Any ideas would help.
-Matt
post May 1, 2007 - 10:28 AM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
I had this happen to my old Nissan Sentra. It would take around 20-30 tries to get it to turn over. I ended up replacing my starter in the end. You can try to change the solenoid, but it didn't fix my problem. kindasad.gif
post May 1, 2007 - 10:29 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
low battery? try jumping it and see if that solves it. if it does its most likely a charging component or the battery itself.
post May 1, 2007 - 12:12 PM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(x_itchy_b_x @ May 1, 2007 - 10:29 AM) [snapback]552859[/snapback]
+1 on the battery.
How old is it?
You can also take the car to Autozone and have them do the complete test on your battery.
_Gary
post May 1, 2007 - 12:26 PM
slick_celica
Joined Sep 21, '06
From Kerry, Ireland
Get someone to give the starter a whack with a hammer or something similar while your turning it over and if it starts you need a new starter motor! Otherwise it's more than likely a duff/expired battery!
signature made by jaws4god
post May 1, 2007 - 12:28 PM
DSToyo
Joined Dec 16, '06
From Maryland
QUOTE(x_itchy_b_x @ May 1, 2007 - 11:29 AM) [snapback]552859[/snapback]
x2 fully recharge your battery and then try it, this has happened to me a couple times
post May 1, 2007 - 2:48 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
does it tickticktickticktick when you turn it over, or is it just one tick each time you turn the key.
I put my money on the starter. I had the same problem a year or so ago and the starter was the problem.
**** Photobucket
post May 1, 2007 - 2:56 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE(95CelicaST @ May 1, 2007 - 2:48 PM) [snapback]552958[/snapback]
One tick each time.
And I don't believe it's the battery, because it looks pretty new, and I haven't had any issues with my charging system.
-Matt
post May 1, 2007 - 3:03 PM
95CelicaST
Joined Feb 5, '05
One tick each time.
-Matt
**** Photobucket
post May 1, 2007 - 8:45 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
A weird thing happened. I noticed that when it was doing the clicking, I was low on gas. So, today I filled up, and now it starts no problem! This is baffling me.
-Matt
post May 2, 2007 - 1:35 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
Last time that happened to me was just because of low battery...
post May 2, 2007 - 7:26 AM
qatar11
From Lake Orion, MI
You do not need a new starter!
The reason why the starter ticks and does not start is that the contacts of the switch that turns on your starter are worn out. Everytime you start the car, a large coil in the starter acts like a huge relay to engage the starter motor. When that switch makes, it arcs a bit - taking some of the copper with it. The reason why a fresh battery will sometimes relieve the issues is because it can provide more current to make the connection and it will overcome the high resistance from the worn out contacts.
All you need to do is remove the starter and take it to a "Proper" starter / alternator shop or you can buy these contacts (they are designed to be replaced) for under $10 and replace it yourself. It isn't too hard.
As far as a full tank of gas fixing your problem - I got nothing.....
This post has been edited by qatar11: May 2, 2007 - 7:27 AM
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 2, 2007 - 4:33 PM
vsideboy
Joined Mar 29, '06
From Hull, UK
I got my starter renovated and it turned out to be the battery doh!
post May 2, 2007 - 6:39 PM
Jared95
Joined Apr 24, '07
From lufkin tx
mine did the same thing it just kept getting worse ...It only did it in the colder weather though and its summer now so it just stopped
post May 2, 2007 - 11:56 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
wow, i havent seen qatar's sn since i was posting on celica.net
post May 3, 2007 - 6:49 PM
CelicaST_CALI
Joined Feb 28, '07
ok im having the smae problem,except when i try to start it it continualy clicks.BUT.IF i pump the clutch a few times ands try it it helps once and a while.wtf is it?I dont think pumping clutch would have anything to do with the starter?
BANNED. for life, you moron.
post May 5, 2007 - 4:33 PM
alltracman78
Joined Aug 9, '06
From Ma
Have your batter tested and check the connections.
If both are good, it is most likely your starter.
Probably the contacts. And yes you can replace them, but it all depends how mechanically inclined you are.......
And while they're not that expensive, I've never seen them for under $10.
Under $30 is more accurate.
Filling it with gas has nothing to do with it.
Coincidental....
Pumping the clutch opens and closes the clutch start switch.
Which allows power to flow through the starter.
So you're jolting it, which is why it works.
post May 8, 2007 - 9:57 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
one click is the switch, solinoid & contacts for mine were $8.xx plus tax, not too hard to do yourself, its just gettin everything apart thats the hardest, if you dont know a good parts guy that has all this stuff still all sealed up laying around then i think list is like 14 for the plunger (which you should replace while in there) then 3 for the one contact n like 2.70 for the other or something like that
post May 9, 2007 - 7:58 AM
CupCrazy38
Joined Jul 11, '03
From Kennesaw, Ga
Just had a similar problem with my car. Long story short, the crank sensor broke and was sending wrong signals to the engine. Car is at the toyota dealer right now getting fixed because I don't have the time or the tools to even get to the crank sensor.
Originally thought my problem was with my starter or voltage regulator. Eh, such is life.
post May 9, 2007 - 10:43 AM
qatar11
From Lake Orion, MI
QUOTE(alltracman78 @ May 5, 2007 - 5:33 PM) [snapback]554508[/snapback]
To be more accurate if you go to a starter specific shop and not Toyota Parts - you will find these parts under $10
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
Lo-Fi Version Time is now: January 15th, 2025 - 4:05 PM
