> Need Rebuild Help, Wiring Harness
post May 1, 2007 - 12:39 PM
Jhensley
Joined Apr 11, '07
From Lafayette, IN
OK so I started my rebuild project a month ago, working on it after classes and work and I need some help on two harness I cannot place.
The car is a '95 Celica ST (California)
Both wires are on the intake side.
1. On the same wire cluster as the downstream 02 sensor, and a lead to a vacuum control switch.
Two prong connector (black/red and brown wires).
2. Out of the injector wire harness (the solid black plastic box under the intake).
One prong connector (blue-ish wire).
Can anyone help me with what these goto? I've been staring down there for an hour or so and cannot see any clips that need a harness.
Also if anyone knows where I can find some good information on the vacuum line routing (EGR, EVAP...etc.) and wire routing could you please post it?
Thanks for your help in advance.
Lo-Fi Version Time is now: February 23rd, 2025 - 2:58 AM
