Loose A - Arm, I need someone to confirm I am pooched |
May 1, 2007 - 7:20 PM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
So I have a 6G That I was going to get back on the road so I can get rid of my POS SVT Focus (which is for a different rant). The reason I bought the fukkus is because the Celica had a loose A-Arm as a result of some bad judgment in "speeding up" the process of a clutch replacement.
Basically We tried to remove the A-Arm from the sub frame as opposed to taking the knuckle apart to remove the drive axle. At some point in backing out the bolt that holds the A-Arm to the sub frame (also the hinge point) the nut that I assume is welded inside the sub frame busted loose and the bolt is now extremely loose and the entire A-Arm can float 2 - 4" in many unfriendly directions. This of course has resulted in a lot of angry noise and 4 destroyed tires if you try to drive on it. I just want a few other people to confirm that I am in fact up ****s creek and I will tear out the front end and get my ST205 conversion started up... So take a look at these pics so you can see the problem area in question aforementioned ST205 Bits -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
May 3, 2007 - 7:23 PM |
mike, you'll need to cut and re-weld the nut in place, if you can.
my cousin just went thru this on his duece. the rear crossmember for that runs 600+ @ toyota..lmao -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: January 10th, 2025 - 9:07 PM |
