i need help (3sgte swap) |
May 4, 2007 - 8:51 AM |
Enthusiast Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
the two plugs i dont know where it goes anymore? the throttle cable where do i mount it at? another picture of my cable the last 2 vaccuum hoses that im not sure what goes into it.. so yeah 3sgte swap people can yah help me get this stuff straight...thanks This post has been edited by RUNNIN-LOW: May 4, 2007 - 9:01 AM -------------------- |
May 4, 2007 - 9:29 AM |
Seems as though your missing the mount that goes on the throttle cable. Might wanna check the Alltrac forums for that part.
Those 2 vacuum hoses look like they should go to the charcoal cannister, but its been awhile since I messed around with them. This post has been edited by Supersprynt: May 4, 2007 - 9:30 AM -------------------- |
May 4, 2007 - 10:03 AM |
nice 3rd gen!
May 4, 2007 - 10:04 AM |
the black plug on the right goes to your coil. the vac lines go to your ac idle up stuff. you can put a vac cap over them . your also missing the throttle bracket, factory catch can, as well as your coil, from what i can see. you might also want to clean all the rust off that igniter bracket or get a new one, because your car might not run if that bracket is not bolted to a good ground, or has that much rust on it.
This post has been edited by lagos: May 4, 2007 - 10:07 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 4, 2007 - 12:12 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
Your pictures aren't showing up for me... but this might help you a bit:
This is the clip I used for my swap before I bought it. If the pictures show up for me, I can help you out some more... -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:37 PM |
