> tiny hid pulsation?
post May 5, 2007 - 10:06 AM
Newb
Joined May 3, '07
hey just put a hid kit in the lowbeams of a 94 gts (canadian), my problem is that its pulsating just a tiny tiny bit around the very edge of the light, you've got to look pretty hard to notice it but it is there and most of the time, it seems to sort of come and go. Is this normal? is there a way to fix it? thanks very much for any help.
post May 5, 2007 - 10:25 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(Newb @ May 5, 2007 - 10:06 AM) [snapback]554436[/snapback]
nop that's not normal, could be one of two things
1- you have low current
2- that ballast is ready to go
post May 5, 2007 - 10:52 AM
Newb
Joined May 3, '07
QUOTE(Culpable04 @ May 5, 2007 - 3:25 PM) [snapback]554442[/snapback]
ok im gona double check all my grounds, upgrade where nessicary and perhaps upgrade batteries.
post May 5, 2007 - 1:57 PM
Culpable04
Joined Apr 17, '06
From New Jersey
before you go out and spend money on something that may not be necessary , if is only one ballast with this problem, swap it to the other side and see if still does the same and check if the one working properly works fine on the other side.
post May 5, 2007 - 5:51 PM
Newb
Joined May 3, '07
QUOTE(Culpable04 @ May 5, 2007 - 6:57 PM) [snapback]554477[/snapback]
good idea actually, i think its both that are doing it but ill double check tonight when it gets darker. I also Upgraded the main chassis ground, the old one looked pretty tiny and a little rusty so hopefully that helps some.
post May 9, 2007 - 4:07 PM
Newb
Joined May 3, '07
QUOTE(Newb @ May 5, 2007 - 10:51 PM) [snapback]554532[/snapback]
well i triple checked the connections remounted the ballasts to what i thought was a better spot, upgraded the main ground, and sercured everything good this time and yea no more pulsation.
post May 9, 2007 - 6:49 PM
Culpable04
Joined Apr 17, '06
From New Jersey
Glad to know that.
Lo-Fi Version Time is now: December 12th, 2024 - 9:14 AM
