lifters *edit* need help, on a 95 st |
May 7, 2007 - 5:32 PM |
Enthusiast Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) |
Does the 7A on a 95 celica st have lifters?
i got something clicking and just wondering if it could be them... *edit* lifters are clicking how do i fix that, seafoam, valve treatement, and ATF didnt work, arggg This post has been edited by Redline08: May 8, 2007 - 7:36 PM |
May 7, 2007 - 7:14 PM |
Enthusiast Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
Yes.
It is what the shims sit on. They are bucket lifters, and look like their name. They probably are what is ticking, Toyota engines are notorious for this. You can check the clearance, but normally they don't go out of spec, even on high mileage engines. -------------------- |
May 7, 2007 - 9:37 PM |
Very common with Toyota's Buckets/shims. You should hear my 20V... tick tick tick. Injectors also tick a fair bit...
-------------------- "It's ok to be naked girl... I'm an artist!"
May 8, 2007 - 5:30 PM |
yea its really really embarrasing, almost everyone i know says its a POS and im gonna throw a rod or a bearing any minute now,
any ideas on how to fix it, or at least quiet them a little? (i tried ATF, didnt work) |
May 8, 2007 - 8:44 PM |
my injectors tick louder than my valve train. is a crisp ticking or a muffled ticking? more of tock than a tick.
tick is injectors, tock is valve train noise. you can use a screw driver like a stethoscope to listen to the topend and the injectors to figure where exactly the noise is coming from you know. -------------------- |
May 8, 2007 - 9:02 PM |
QUOTE(Redline08 @ May 8, 2007 - 5:30 PM) [snapback]555476[/snapback] yea its really really embarrasing, almost everyone i know says its a POS and im gonna throw a rod or a bearing any minute now, Well, ask them how ticking lifters will cause you to throw a rod or spin a bearing...... And post up the answers. They should be interesting....... QUOTE(Redline08 @ May 8, 2007 - 5:30 PM) [snapback]555476[/snapback] any ideas on how to fix it, or at least quiet them a little? (i tried ATF, didnt work) Assuming it is your lifters, nothing. Like I [and Kwanza] told you, it's part of owning a Toyota. You just have to deal with it. -------------------- |
May 8, 2007 - 10:43 PM |
My motor ticks quite loudly as well...I've just grown used to it.
May 8, 2007 - 10:59 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
The clearence adjustment should help if it is out, if it hasn't
been apart it shouldn't be out of adjustment. Is it something that just started? This post has been edited by 97lestyousay: May 8, 2007 - 11:19 PM -------------------- JDM guy made me do it.
May 9, 2007 - 12:03 AM |
Enthusiast Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
my lifters are quite noisy also. i can hear them and my fuel injectors even w/ the hood closed. somtimes it'll stop after i revv though...
May 9, 2007 - 8:58 AM |
Enthusiast Joined Nov 29, '06 From Newnan, Ga. Currently Offline Reputation: 3 (100%) |
I've got a set of 7afe rods when yours let loose.(cheap)
May 9, 2007 - 1:52 PM |
really i cant do anything?
that sucks cause its really bad, and really embarrassing, if it helps i noticed when the engine is cold, like right when i start her up, i dont hear any ticking does this change the scenario any? |
May 9, 2007 - 6:22 PM |
Dunno man
It's REALLY hard to conclusively diagnose noises online.... You can always check the clearance, but it's normally not out. -------------------- |
May 9, 2007 - 8:27 PM |
QUOTE Dunno man It's REALLY hard to conclusively diagnose noises online.... i can get video, it will just take a day or two, check back soon thanks This post has been edited by Redline08: May 9, 2007 - 8:27 PM |
May 9, 2007 - 8:56 PM |
QUOTE(Redline08 @ May 10, 2007 - 1:27 AM) [snapback]555917[/snapback] QUOTE Dunno man It's REALLY hard to conclusively diagnose noises online.... i can get video, it will just take a day or two, check back soon thanks Check your shim cleareances... buy new shims/buckets... then *HOPE* it helps. A lot of the times... it doesn't help that much. -------------------- "It's ok to be naked girl... I'm an artist!"
Lo-Fi Version | Time is now: December 4th, 2024 - 2:38 PM |
