![]() Enthusiast ![]() Joined Dec 22, '05 From Turlock, CA Currently Offline Reputation: 0 (0%) ![]() |
I need some help on how to corretly install the green wire for the tach, I have a 7AFE engine. This should be fairly straight foward I just want to make sure I do it correctly. I know the green wire is supposed to be connected to the negative ignition wire by using an electrical connector. If anyone has pics on how to do this let me know. Thanks.
![]() -------------------- www.cardomain.com/id/snakesolid
![]() Enthusiast ![]() ![]() ![]() Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) ![]() |
hey ive always wanted to install a tach on my 7A,
can you write up how you did this when your done? sorry i dont have an answer, but good luck and thank you |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
QUOTE(juan_solid @ Jun 2, 2007 - 3:04 PM) [snapback]564263[/snapback] I need some help on how to corretly install the green wire for the tach, I have a 7AFE engine. This should be fairly straight foward I just want to make sure I do it correctly. I know the green wire is supposed to be connected to the negative ignition wire by using an electrical connector. If anyone has pics on how to do this let me know. Thanks. ![]() wow your engine bay is sooooo clean! -------------------- |
amen thats a hot engine,
how is the install coming? |
QUOTE(Redline08 @ Jun 3, 2007 - 1:45 PM) [snapback]564463[/snapback] amen thats a hot engine, how is the install coming? I finished the install I'll post some info and pics on the weekend. -------------------- www.cardomain.com/id/snakesolid
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) ![]() |
Its not one of those GIANT tachs is it?
![]() You have a perfectly good one next to your speedometer. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: February 13th, 2025 - 11:59 AM |
