Sunroof, How to open manually ?? |
Jun 23, 2007 - 10:04 AM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Anybody know of a way to open the sunroof manually ?? Or is that not possible ??
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Jun 23, 2007 - 10:54 AM |
Enthusiast Joined Apr 24, '07 From lufkin tx Currently Offline Reputation: 0 (0%) |
all i know is that if i does not work and its open its a b**** to close.
Jun 23, 2007 - 3:51 PM |
Will mines not broken or anything just wanted to know if you can open the sunroof manually without braking it or cracking the sunroof. Maybe from the inside of the car ??
Jun 23, 2007 - 3:57 PM |
Moderator Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
QUOTE(Remy @ Jun 23, 2007 - 3:51 PM) [snapback]571612[/snapback] Will mines not broken or anything just wanted to know if you can open the sunroof manually without braking it or cracking the sunroof. Maybe from the inside of the car ?? Why???? -------------------- |
Jun 23, 2007 - 7:26 PM |
QUOTE(manphibian @ Jun 23, 2007 - 3:57 PM) [snapback]571613[/snapback] QUOTE(Remy @ Jun 23, 2007 - 3:51 PM) [snapback]571612[/snapback] Will mines not broken or anything just wanted to know if you can open the sunroof manually without braking it or cracking the sunroof. Maybe from the inside of the car ?? Why???? I need some parts from it. Found a celi at a junkyard just wanted to know if you can manually open it up thats all. -------------------- "To Protect And To Serve The Wealthy" -POLICE
Jun 23, 2007 - 8:04 PM |
Enthusiast Joined Jul 11, '06 From Sefner, FL Currently Offline Reputation: 24 (100%) |
take off teh sunroof control bezel and look up and u will see a big gold flathead screw, turn that and it will manually/open/close, be careful its had to turn adn it strips easy
Jun 23, 2007 - 9:45 PM |
QUOTE(illneversellmycelli @ Jun 23, 2007 - 8:04 PM) [snapback]571646[/snapback] take off teh sunroof control bezel and look up and u will see a big gold flathead screw, turn that and it will manually/open/close, be careful its had to turn adn it strips easy Ok thanks for the info illneversellmycelli -------------------- "To Protect And To Serve The Wealthy" -POLICE
Jul 11, 2007 - 9:58 AM |
Enthusiast Joined Nov 14, '06 From michigan Currently Offline Reputation: 10 (100%) |
you can also remove the interior plastic trim from around the sunroof and then take out the 4 bolts that hold the glass in place and remove the glass
Jul 11, 2007 - 10:43 AM |
you can't move it manually i'm pretty sure.
though i have a great condition OEM sunroof for sale |
Lo-Fi Version | Time is now: December 3rd, 2024 - 4:06 PM |
