Auto Trans Turbo |
Auto Trans Turbo |
Jul 1, 2007 - 11:04 PM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
I do some of the bro's here was running turbo with auto transmission. May i know what ATF oil do you guys use? All the while im using ori from toyota but im looking to try Amsoil. Any recomendation here?
Jul 2, 2007 - 10:10 PM |
Enthusiast Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
QUOTE(normality78 @ Jul 1, 2007 - 11:04 PM) [snapback]574203[/snapback] I do some of the bro's here was running turbo with auto transmission. May i know what ATF oil do you guys use? All the while im using ori from toyota but im looking to try Amsoil. Any recomendation here? i run valvoline high milage atf in my auto and i have been turboed for over a year and a half -------------------- |
Jul 2, 2007 - 10:13 PM |
trd94,
just to check q few thing. I notice there is quite some series of Valvoline ATF oil. which is the one? do you feel the different after switch to valvoline frm toyota ori atf oil? have you tried others brand? This post has been edited by normality78: Jul 2, 2007 - 10:14 PM |
Jul 2, 2007 - 10:16 PM |
wtf is an ori?
Jul 2, 2007 - 10:21 PM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
QUOTE(lagos @ Jul 2, 2007 - 11:16 PM) [snapback]574564[/snapback] wtf is an ori? WTF is a LAGOS? (i actually know what it is) back on topic. TRD94, youve been boosted for 18 months? Whats your daily PSI? Any issues uve encountered? Hows normal driving and what not? Easy to hold boost/go on and off? -------------------- Kawi Love |
Jul 2, 2007 - 11:01 PM |
QUOTE(lagos @ Jul 2, 2007 - 8:16 PM) [snapback]574564[/snapback] wtf is an ori? common lagos your getting old. ori is original. =p is there an full synthetic auto dex 3 fluid? |
Jul 3, 2007 - 5:22 PM |
as far as valvoline goes i have always used it since i owned the car (2001) i have tried differant brands in my other cars and i could tell a defferance. i use the high mileage brand of valvoline even in the motor & power steering....... now as far as boost goes i run 10psi daily no problems. at very first i had some issues but everyone does when they try to cut corners, i learned that the hard way. when building a turbo kit you get what up pay for, and at first i tried to build it as cheap as possiable , used turbo, a log mani that had a lot of clearance issues, ebay couplers, junk yard intercooler, and harware oil lines, had problems with them all every week ,and in the end replaced them with the good ones . so if i would of done that in the first place i would of not spent so much...HA!!HAA!!!.... now with my t3-t4 i boost real good i hit boost at 2700rpm and full boost at 3600rpm , and what is nice about the auto is every shift under boost i get 1-2 psi more rather then losing boost like the manuals. now on track days i have pushed my setup to 17psi ,but i dont recomend any one to do this on a stock 7a ,12 psi is as far as i would go on a dd car . if you want more then swap or build up the 7a . i am working on a 20v 7agte right now and hopefully i will have it done by next summer . looking for 250-300hp daily.
Jul 4, 2007 - 6:02 AM |
hm... i think i will give it a try since its always no harm. I do run 12 psi daily but doesnt means keep on max boost it. maybe once per day? i do have external cooler installed though
Jul 4, 2007 - 1:11 PM |
a external trans cooler is a good idea .i put one on to along with a small fan for when i am stuck in traffic on hot days.
Jul 5, 2007 - 6:40 PM |
Enthusiast Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
QUOTE(trd94 @ Jul 4, 2007 - 12:11 PM) [snapback]574979[/snapback] a external trans cooler is a good idea .i put one on to along with a small fan for when i am stuck in traffic on hot days. I've been running around 10psi for a while on my auto ...i'm still running on the ori trans fluid, added a external cooler though, what are ya'll using to control fuel? and how are ya'll monitoring it? |
Jul 5, 2007 - 8:01 PM |
whahahaa, that is diff topic all together.
Jul 5, 2007 - 9:39 PM |
QUOTE(southwest2118 @ Jul 5, 2007 - 6:40 PM) [snapback]575363[/snapback] QUOTE(trd94 @ Jul 4, 2007 - 12:11 PM) [snapback]574979[/snapback] a external trans cooler is a good idea .i put one on to along with a small fan for when i am stuck in traffic on hot days. I've been running around 10psi for a while on my auto ...i'm still running on the ori trans fluid, added a external cooler though, what are ya'll using to control fuel? and how are ya'll monitoring it? i use a safcII for management and a adjustable fpr with a 255 walbros pump, right now, i will be running emanage soon This post has been edited by trd94: Jul 5, 2007 - 9:39 PM -------------------- |
Jul 5, 2007 - 11:00 PM |
Used to have SAFCII. Thn now on Emanage. Going for S/alone soon
Lo-Fi Version | Time is now: December 4th, 2024 - 6:03 PM |
