> Clunking noise in steering, Is it CV joint?
post Jul 15, 2007 - 3:43 AM
Mangozac
Joined Mar 13, '07
From Gold Coast, QLD, Australia
Hi team,
I've noticed lately that my steering is making a funny noise when I pull into my driveway. It happens when the wheel is at full lock. My drivers side CV joint makes the usual worn knocking noise when I go around corners and this noise in the steering is on the same side. The noise when I'm pulling into the driveway is like a couple of clunks as the wheels turn. It also only seems to happen under load (i.e. if I just turn the wheels without moving it doesn't happen)...
Do you guys think it could be the CV or something more sinister? Anything I should check out? Power steering fluid is at the right level. kindasad.gif
Zac
post Jul 15, 2007 - 5:10 PM
malecrod
Joined May 30, '05
From MN
QUOTE(Mangozac @ Jul 15, 2007 - 3:43 AM) [snapback]578699[/snapback]
Hi team,
Zac
It's possible it could be CV joint or your rack-and-pinion. Just my guess though.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Jul 15, 2007 - 9:46 PM
Mangozac
Joined Mar 13, '07
QUOTE(malecrod @ Jul 16, 2007 - 8:10 AM) [snapback]578849[/snapback]
Yeah I'm hoping it's not the actual rack and pinion because that sounds like a pain to fix kindasad.gif
Actually, I noticed this morning that it's not only at full lock that it happens and in retrospect it does sound very possible like a problem with the rack. If that is the problem can it be fixed without too much drama like replacing the whole steering assembly?
post Jul 15, 2007 - 10:35 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
i have the same situation and i know i dont have a bad cv joint.....so any advice how to remedy teh sound???
post Jul 16, 2007 - 9:07 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
98% says its the axle
post Jul 16, 2007 - 11:06 AM
Valo666
Joined May 15, '05
From Toronto
it could be axel or it could also be strut bearing. I have a bad strut mount/bearing on my passanger side and when ever i turn my wheel hard left or right just b4 full lock, i hear a bad clunking sound. My first strut bearing went bad and was fully seazed and then started cutting into the mount its self.
post Jul 18, 2007 - 6:02 PM
alltracman78
Joined Aug 9, '06
From Ma
Well, the first thing to do is fix the known problem [bad CV joint].
If you have a good tech around they could probably locate the noise [if it's not the axle], but if you know the joint is bad why leave it?
IMO fix it and see if the other noise is still there.
post Jul 21, 2007 - 6:04 PM
Mangozac
Joined Mar 13, '07
QUOTE(alltracman78 @ Jul 19, 2007 - 9:02 AM) [snapback]579964[/snapback]
Yeah I know I need to get the CV fixed but I just wanted to scope out the problem and see if anyone else had experienced it. Looks like I'll just have to go see a mechanic...
post Jan 12, 2008 - 4:16 PM
swerve
Joined Mar 18, '06
From Brisbane - Australia
QUOTE(malecrod @ Jul 16, 2007 - 9:10 AM) [snapback]578849[/snapback]
Hi team,
Zac
Hi Guys,
I have been going through the same issue for some time now (around 6 months) I had Fulcrum susspension have a look and they replaced the rack end. Issue wasn;t resolved so I thought it must be bearings or cv joint. I had someone else have a look and the rack end was in fact not replaced properly (not seated). Check the left rack end. These are notorious for "popping out". The noise I hear down low is a clunk when I turn the steering. At faster speeds I get continuous rotational vibration when steering is under load. That's my 2 cents, check it out
post Jan 12, 2008 - 5:50 PM
Mangozac
Joined Mar 13, '07
QUOTE(swerve @ Jan 13, 2008 - 7:16 AM) [snapback]630293[/snapback]
Hi Guys,
Hey Swerve thanks for the pointer. I had Pedders to a 28 point check and they said that the rack needs replacing. I'll check out the rack end now because I too am experiencing some nasty vibration (although that could simply be due to my bushes needing replacing)...
Lo-Fi Version Time is now: February 20th, 2025 - 3:01 PM
