Servicing the GT4 |
Servicing the GT4 |
Jul 17, 2007 - 3:05 PM |
Enthusiast Joined Jun 13, '07 From U.K Currently Offline Reputation: 0 (0%) |
Im planing on servicing the car every 6000 miles, so its now due for an oil change... Fully synthetic oil etc... As im not an experienced gt4 owner,
What else needs changed when i do this?? Does the oil filter need changed etc?? Thanks guys -------------------- |
Jul 17, 2007 - 3:19 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
QUOTE(3SGTE @ Jul 17, 2007 - 4:05 PM) [snapback]579486[/snapback] Im planing on servicing the car every 6000 miles, so its now due for an oil change... Fully synthetic oil etc... As im not an experienced gt4 owner, What else needs changed when i do this?? Does the oil filter need changed etc?? Thanks guys Yes, the oil filter need to come out. It is at the bottom, front, driver side of the engine block. 6,000 miles is little stretch for turbo engine IMO. I change oil every 4-6 months. (that would be about 750 miles on my car) Also cleaning/replace your air filter, rotate tires, check all fluid level (transmission, rear diff, coolant) -------------------- _Gary
Jul 17, 2007 - 3:26 PM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
oil changes should happend every 3000 miles....or 2500 if you have a turbo..
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
Jul 17, 2007 - 5:26 PM |
yeah, oil and filter ever 2500-3000 miles.
Jul 17, 2007 - 6:17 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(lagos @ Jul 17, 2007 - 3:26 PM) [snapback]579530[/snapback] yeah, oil and filter ever 2500-3000 miles. The stock turbo is water cooled and doesn't coke the oil like oil cooled turbos... I'd be happy to see evidence otherwise, but 90k+ miles on a similar turbo motor (my WRX) says 5k-7k between oil changes has no ill effects (no oil burning, perfect compression, turbo still good, etc.). -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Jul 18, 2007 - 5:41 AM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
QUOTE(phattyduck @ Jul 18, 2007 - 12:17 AM) [snapback]579550[/snapback] QUOTE(lagos @ Jul 17, 2007 - 3:26 PM) [snapback]579530[/snapback] yeah, oil and filter ever 2500-3000 miles. The stock turbo is water cooled and doesn't coke the oil like oil cooled turbos... I'd be happy to see evidence otherwise, but 90k+ miles on a similar turbo motor (my WRX) says 5k-7k between oil changes has no ill effects (no oil burning, perfect compression, turbo still good, etc.). -Charlie Every 3000 miles is a little extreme unless your using cheap crap oil, if you buy good quality synthetic oil then every 5-6000 miles is a good guide to go by..otherwise like mentioned your gonna be throwing away your money. |
Jul 18, 2007 - 10:57 AM |
im shocked at how you guys treat your cars! ever look at your oil after 3k miles? the change in color is reason enough to change it. not to mention that even the owners manual states 3k oil changes. especially on a turbo car that sees high oil temps.
Jul 18, 2007 - 11:01 AM |
every 2500 / 3000 here, depending on how i drive it. oil is an engines blood. i want it using the best at all times. check my levels religiously also. This post has been edited by x_itchy_b_x: Jul 18, 2007 - 11:01 AM -------------------- |
Jul 18, 2007 - 11:09 AM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
waste of money IMO, but if somebody wants to prove otherwise (next time you change your oil at 2500/3000 have someone analyze it, they will tell you whether you needed to change it or not.
especially you guys running synthetic, you are just pouring money down the drain. my audi has been changed every 5k miles , with mobil 1 fully synthetic 0w40. still has like new compression at 140k. edit: do a quick google search, i found a guy with a bmw who got his oil tested at 15k and it said "suitable for use" and also a guy with a turbo diesel (even harder on oil than gas) at 10k said suitable for use. the key is the type of oil, dont buy the cheap **** and go for 10k miles, but 99% of the time the interval suggested on the box is not going to do your motor any harm. This post has been edited by brianforster: Jul 18, 2007 - 11:14 AM |
Jul 18, 2007 - 11:25 AM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
i change my oil and filter every 3500 miles. it may be more expensive, and sum may say its illogical, but it'll keep ur engine life a lot healthier. this is for a non turbo car tho.
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Jul 18, 2007 - 12:54 PM |
What oil should you use?? Phoned Toyota and they said they would change the oil and filter for £40/$80. When i asked what oil it was they said semi-synthetic.. I thought you had to use Fully-synthetic. i got 5w/40 in right now
Jul 18, 2007 - 12:58 PM |
QUOTE(3SGTE @ Jul 18, 2007 - 1:54 PM) [snapback]579845[/snapback] What oil should you use?? Phoned Toyota and they said they would change the oil and filter for £40/$80. When i asked what oil it was they said semi-synthetic.. I thought you had to use Fully-synthetic. i got 5w/40 in right now change it yourself. mobil1 10w30 is what most people use on turbo cars. -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(3SGTE @ Jul 18, 2007 - 1:54 PM) [snapback]579845[/snapback] What oil should you use?? Phoned Toyota and they said they would change the oil and filter for £40/$80. When i asked what oil it was they said semi-synthetic.. I thought you had to use Fully-synthetic. i got 5w/40 in right now You don't "have to" use full synthetic. But dino oil will go bad faster than full synthetic. I only use full synthetic in my car. -------------------- _Gary
Jul 18, 2007 - 2:35 PM |
QUOTE(Gary @ Jul 18, 2007 - 6:58 PM) [snapback]579848[/snapback] You don't "have to" use full synthetic. But dino oil will go bad faster than full synthetic. I only use full synthetic in my car. Oh right, cos they reccomended 10w/50 i think.... its cheaper for me to get them to do it... ill give it a shot in the future when i get my garage built!! -------------------- |
Jul 18, 2007 - 3:51 PM |
QUOTE(3SGTE @ Jul 18, 2007 - 12:35 PM) [snapback]579892[/snapback] QUOTE(Gary @ Jul 18, 2007 - 6:58 PM) [snapback]579848[/snapback] You don't "have to" use full synthetic. But dino oil will go bad faster than full synthetic. I only use full synthetic in my car. Oh right, cos they reccomended 10w/50 i think.... its cheaper for me to get them to do it... ill give it a shot in the future when i get my garage built!! -Charlie -------------------- 2003 Subaru WRX Wagon
Jul 18, 2007 - 4:05 PM |
QUOTE(lagos @ Jul 18, 2007 - 8:57 AM) [snapback]579771[/snapback] im shocked at how you guys treat your cars! ever look at your oil after 3k miles? the change in color is reason enough to change it. not to mention that even the owners manual states 3k oil changes. especially on a turbo car that sees high oil temps. The 3 month / 3k miles suggestion comes from Jiffy Lube and other places that make money when you come in for an oil change. Car manufacturer suggestions are much longer. BTW, I have about 4k miles on my current oil change on my 3s-gte and the oil is a golden and down about 1/4 quart. This is with a small oil leak. I don't see a reason to change the oil yet. I do have a Fumoto oil valve if I want to check the quality of the oil though! -Charlie -------------------- 2003 Subaru WRX Wagon
Jul 18, 2007 - 5:16 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
u guys are crazy, waste of money or not, i change mine every 3 months or so, about every 800miles since the car is in the garage most of the time for days on end, i try to use the other cars whenever they are available to me....
10w30 Mobil 1 btw... |
Jul 18, 2007 - 5:51 PM |
Enthusiast Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) |
Well you learn something new every day....
I was under the impression Toyota recommended 5k oil changes for regular engines and 2.5k changes for turbo engines. But I decided to check to be sure. For rough conditions [towing, dusty, extensive idling, ect] the interval is 2.5k [3 months] miles for turbo engines [filter is 5k [6 months] miles, so every 2 oil changes] and 3.75k [6 months] for regular engines, with the filter changed every time. For regular conditions [applies to most of us] the turbo engines are actually 5k [6 months] miles, with filter changes every 10k [12 months] miles. Regular engines are 7.5k [12 months] miles for oil and filter changes. And that is on dino [regular, non synthetic] oil. So, corporate Toyota, that stresses reliability, is comfortable changing oil at some pretty extended intervals..... Personally, I was changing mine every 3 months, 3k miles with Mobil 1. But recently [nothing to do with this thread] I've started thinking about getting it tested first..... In the Marine Corps [and the other services] oil isn't changed on a time or mileage interval, it's sent to be tested, and changed when it's worn out, or too full of contaminates. That includes the turbine engines in tanks, planes and helicopters. If you think your turbo engine runs hot, runs hard, or runs in rough conditions, think again. You don't have ****e on those engines. They do run a very high quality synthetic oil in them though, not regular oil. -------------------- |
Jul 19, 2007 - 12:44 PM |
QUOTE(alltracman78 @ Jul 18, 2007 - 3:51 PM) [snapback]579957[/snapback] Well you learn something new every day.... I was under the impression Toyota recommended 5k oil changes for regular engines and 2.5k changes for turbo engines. But I decided to check to be sure. For rough conditions [towing, dusty, extensive idling, ect] the interval is 2.5k [3 months] miles for turbo engines [filter is 5k [6 months] miles, so every 2 oil changes] and 3.75k [6 months] for regular engines, with the filter changed every time. For regular conditions [applies to most of us] the turbo engines are actually 5k [6 months] miles, with filter changes every 10k [12 months] miles. Regular engines are 7.5k [12 months] miles for oil and filter changes. And that is on dino [regular, non synthetic] oil. So, corporate Toyota, that stresses reliability, is comfortable changing oil at some pretty extended intervals..... I do about 70% highway driving (20 to 50 mile trips, mostly) and change my oil with Mobil 1 and a new stock filter every 5-7k, which is right in line with manufacturer recommendations. Often people do oil tests on race motors just to check if there is bearing damage or too much blow-by (metals in the oil or fuel in the oil, etc). Any idea how much the tests cost? I've been curious for a while on my motors... -Charlie -------------------- 2003 Subaru WRX Wagon
Jul 19, 2007 - 8:31 PM |
I don't know how much yet, I'll probably check into it one of these days.
I just have too much crap going on right now. One note on BMW and Audi. BMW at least has larger oil pans that normal. More oil means less stress on the individual molecules. -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 5:18 PM |
