Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '06 From Nashville Tennessee Currently Offline Reputation: 5 (100%) ![]() |
Ok so i bought this autometer cobalt widband and i cant help but think im installing it all wrong.
is it ok to install the o2 sensor that came with the wideband where the stock o2 sensor is because its in the perfect location length wise for the widbands o2 sensor to be. Also if i do put it where the stock o2 sensor is can i just leave the the stock one out?. This post has been edited by Shocker: Jul 23, 2007 - 10:08 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) ![]() |
QUOTE(Shocker @ Jul 23, 2007 - 10:18 PM) [snapback]581745[/snapback] Ok so i bought this autometer cobalt widband and i cant help but think im installing it all wrong. is it ok to install the o2 sensor that came with the wideband where the stock o2 sensor is because its in the perfect location length wise for the widbands o2 sensor to be. Also if i do put it where the stock o2 sensor is can i just leave the the stock one out?. u have to make a new spot for the wideband the ecu still has to read both sensors This post has been edited by jesterwr217: Jul 24, 2007 - 9:27 PM -------------------- ![]() BOOST GETS YOU LAID!!!! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
a) you have to leave the STOCK sensor in the STOCK location (these are the only ones your ECU will see to make adjustments)
b) your ecu doesn't read the wideband c) take the car down to your local exhaust shop and have them weld in an extra o2 bung in the midpipe |
Lo-Fi Version | Time is now: February 25th, 2025 - 11:56 AM |
