> 7afe to 4age swap, motor swap
post Sep 1, 2007 - 2:47 AM
white97
Joined Sep 1, '07
From south carolina
i own a 97 st with a 7afe in it, which is slowly going down hill. i want to put the 4age motor in it. so is there anyone who can give me some info on the swap?
post Sep 5, 2007 - 3:26 AM
mikeismad0408
Joined Mar 22, '07
From Greenville NC
direct swap? just need new harness and ecu i think.
post Sep 5, 2007 - 5:20 AM
SinisterWhisper
Joined Nov 14, '04
If you plan to modify the engine down the road get the 2nd generation silvertop. If you are going to leave it stop get the blacktop. Both are a series blocks and bolt directly in. You can either do the wiring yourself or pay for another member to do it for you for a few hundred bucks.
post Sep 5, 2007 - 9:28 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
The 7A - 4A swap is probably one of the easier swaps for the Celica. Since the motors are both A-series they can be swapped and directly implanted. The 4A-GE will drop straight into an ST's motor mounts and bolt up with the C-52 transmission (however if you get a 4A-GE Silver or blacktop I would suggest using the trans that comes with). The only thing needed for the swap is wiring. Wiring is a tedious process, and is best left handled to the professionals, so when you get your motor and such for the swap get in touch with Dr. Tweak (just search for the member name) and send him the 4A-GE and 7A-FE harnesses. He can rewire the harness for you so that all you have to do is hook it back up. It'll run you $300ish for the work on the harness, but you should be able to swap the motors pretty quick and easy with the right tools (Cherry picker, air tools, etc.)
**** Photobucket
post Sep 5, 2007 - 4:30 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
Like 95CelicaST said, you will need to have a wiring harness conversion, and Dr. Tweak is the man do to this for you. Go to his site at http://www.phoenixtuning.com and email him about his services. If plan you on keeping your a/c and power steering, you will need to custom fab. a few hoses and lines so they work accordingly with the engine swap. The exhaust will need to be custom made to either run from the engine's downpipe and straight to the rear of the car, or you go with another option and weld the engine's downpipe to the celica's existing exhaust setup.
This post has been edited by netrata: Sep 5, 2007 - 4:46 PM
post Sep 12, 2007 - 11:42 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
WRONG! Most people say its a direct drop with the WIRING BUT you will need a THROTTLE CABLE off of a 5S or 3S motor in order to fully use your gas pedal cause the 7A does not reach the 4A hence the RHD style.
Throttle cable is pretty much a bolt on too.
post Sep 12, 2007 - 12:21 PM
95CelicaST
Joined Feb 5, '05
...Or from a Paseo
**** Photobucket
post Sep 12, 2007 - 6:12 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
or just get a 4afte.... turbo it and act like its a DSM cuz the 4afe's are nearly 284 bucks now!.... one i saw for 45k miles. oh dear lord tongue.gif
totally off topic btw
This post has been edited by Blakout16: Sep 12, 2007 - 6:12 PM
post Sep 24, 2007 - 8:19 PM
white97
Joined Sep 1, '07
From south carolina
does anyone know someone one here thats done this swap before???
post Oct 11, 2007 - 11:42 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Netrata in this thread has done it, Coomer (the forum owner), and probably a dozen others who don't post much/at all.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 7, 2008 - 1:53 PM
20v_celica
Joined Mar 3, '08
From BP, MN
QUOTE(white97 @ Sep 24, 2007 - 8:19 PM) [snapback]598775[/snapback]
im doing the swap right now, motor drops right in, stock axles fit, need throttle cable from tercel or paseo, need to custom make high pressure fuel line(if the one on the 4age is cut), need custom fit exhaust, and have someone(Dr. Tweak) do the wiring for u.
post Aug 24, 2008 - 3:27 AM
white97
Joined Sep 1, '07
From south carolina
if i've fixed the fuel line part, do i need to run a 4a fuel pump or can i keep the stock one from the 7a?
post Aug 24, 2008 - 8:09 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (white97 @ Aug 24, 2008 - 3:27 AM) *
keep the stock pump, the only way it'd be recommended to upgrade your pump is if you turbo the motor as the stock ST pump may not deliver enough fuel for a turbo application, but for a 4age it'll be perfectly fine.
post Aug 25, 2008 - 10:45 AM
white97
Joined Sep 1, '07
From south carolina
so the stock 7afe pump is straight? i didnt get a pump for the 4age with the swap so im making sure that its cool to run the stock 7afe pump.
post Aug 25, 2008 - 12:03 PM
j0ch0a94ST
Joined Sep 27, '07
From Raleigh, NC
QUOTE (white97 @ Sep 1, 2007 - 3:47 AM) *
if your looking to do a 4age swap Coomer is your man...he had the cleanest swap i've seen...he could tell you whatever you need to know
post Aug 25, 2008 - 1:06 PM
nik
Joined Sep 30, '02
QUOTE (white97 @ Aug 25, 2008 - 8:45 AM) *
a stock 7afe pump will work fine for a stock 4age
post Aug 25, 2008 - 5:47 PM
white97
Joined Sep 1, '07
From south carolina
thanks man
Lo-Fi Version Time is now: November 28th, 2024 - 10:35 AM
