Enthusiast ![]() ![]() Joined Oct 19, '02 From Spring Valley, NY Currently Offline Reputation: 1 (100%) ![]() |
sup guys....i need help...i installed KYB GR-2 shocks in the front with Eibach Pro-Kit...when i installed the front the springs didn't line up with the strut mount and when i turn the wheel i hear the clunking sound....
am I missing something?? i previously had KONI with Ground Control...threw out all the stuff from the previous OEM strut assembly...what goes after the spring?? is there something between the spring and the strut mount so the wheel wont clunk?? ANY HELP/ADVICE WOULD BE APRECIATED THANX This post has been edited by Ve1Ls1dEvolutioN: Sep 1, 2007 - 9:58 PM |
bump...anyone??
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
did you put a top mount on? did you grease the bearings?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) ![]() |
yeah, lots of grease is needed.
and you did put your bumpstops back in, right? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
QUOTE(95CelicaST @ Sep 3, 2007 - 11:03 AM) [snapback]593004[/snapback] yeah, lots of grease is needed. and you did put your bumpstops back in, right? yeah i grease the bearings...and i put on brand new KYB strut boot/bump stop |
did you put that rubber lining over the spring before it goes on the top
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) ![]() |
QUOTE(LewFX @ Sep 5, 2007 - 6:52 AM) [snapback]593558[/snapback] did you put that rubber lining over the spring before it goes on the top x2 also did you put the bump stops back on to the shock as well???? you could cut the bump stops a little to aid in lowering. This post has been edited by eggman40: Sep 5, 2007 - 11:08 AM |
QUOTE(LewFX @ Sep 5, 2007 - 6:52 AM) [snapback]593558[/snapback] did you put that rubber lining over the spring before it goes on the top didn't have a rubber lining...must have thew them out when i put koni's on 3 years ago...SO THERE IS A RUBBER ON TOP OF THE SPRING?? i'm gonna get a strut assembly from a junkyard and just take that part out... |
the rubber stops the spring from binding on the top mount
yeah i guess thats what i'm missing...cuz it grinds really bad when i turn the wheel and the car is not even moving...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) ![]() |
NVM
This post has been edited by 97lestyousay: Sep 5, 2007 - 10:26 PM -------------------- JDM guy made me do it.
Lo-Fi Version | Time is now: February 17th, 2025 - 5:26 AM |
