> I found some headers that might work!!, For the ST only!!(made for Corolla)
post Aug 10, 2003 - 5:30 AM
aEr
Joined Jul 29, '03
From So Cal
Sup everybody,
I was surfing for some headers for the ST and I found some headers from PowerTech. They have 4-2-1 headers for the 93-97 Toyota Corolla 1.8L. They only go for $175. That's some pretty damn good pricing. Has anybody ever heard of PowerTech? Do you guys think this will work on the ST? I want to know what you guys think before I go buying these headers. If they dont fit on the ST I will loss a lot of cash.
Here's the link:
http://www.speedstash.com/headers.html
post Aug 10, 2003 - 5:41 AM
aEr
Joined Jul 29, '03
From So Cal
I just found a website that sells the OBX headers for 93-97 Toyota Corolla 1.8L. Only for $189.95. There is a possibility that the part has been discontinued.
Here's the website:
http://www.ssautochrome.com/_estore/parser...dex=20&icQuery=
Which would you guys prefer? the Powertech or the OBX headers?
post Aug 10, 2003 - 7:55 AM
Mynzeyes
From Franklin/Nashville, TN
i had the HP Motorsports header on my ST. it was for the same corolla. check out nopi, and put in as your car, a 95 or so corolla..and see if they still have that header listed. smile.gif.
-John-
AIM==Mynzeyes
post Aug 10, 2003 - 3:08 PM
aEr
Joined Jul 29, '03
From So Cal
Did the HP header bolt on directly to your stock exhaust system? Did it fit perfectly on to your engine?
post Aug 10, 2003 - 3:22 PM
Mynzeyes
no it did not. read this ==> 7A-FE Header How-To.
i wrote that a while back. if you need any help after that, lemme know. smile.gif
-John-
AIM==Mynzeyes
post Aug 10, 2003 - 3:39 PM
aEr
Joined Jul 29, '03
From So Cal
Huh, I dont have a torch to make another o2 sensor hole. About how wide is the hole that you needed to make. I can probably drill another hole since I have some pretty big drill bids. I have a weld michine so I'll probably weld my o2 sensor also.
Do all Corollas only have only one o2 sensor? Also you said "BE ADVISED: YOU MAY NEED TO BORE THE HOLES IN ORDER FOR THE HEADER TO SLIDE INTO PLACE", what holes are you talking about? Do you have a picture?
Thanks for your help and you how-to article is great.
Thanks and Peace
Lo-Fi Version Time is now: November 27th, 2024 - 4:29 PM
