need help!!!!!, car nearly overheated |
Oct 5, 2007 - 2:25 AM |
Enthusiast Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) |
i was driving to go to a movie tonight and i noticed my temp gauge fluctuating pretty badly so i get off the freeway and notice steam coming from the hood. i pull over as soon as i can and pop the hood to see coolant all over my motor. i am just lucky i caught it b4 it did overheat. since it was late and dark outside i couldn't see where the leak was coming from. where would be the first place that i should check?
i hope it's just some tubing and not the radiator cuz that would be a lot less of a problem for me. going to pick up the car when i wake up and have my dad check it out to see what's wrong. any help would be much appreciated. i just hope my work won't mind that i may have to call in. This post has been edited by goferris: Oct 5, 2007 - 2:25 AM -------------------- |
Oct 5, 2007 - 9:59 AM |
Enthusiast Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
check all the hoses to the radiator,.
Oct 5, 2007 - 10:14 AM |
Enthusiast Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) |
Yeah, check the hose and where they connect tothe block and radiator.
My radiotor had a crack in it a few years ago and it wasn't a huge problem to change it. Just a few bolts all around, swap the fans to the new radiator, and bolt it back up. Add the fluids and you're done. Took me less than an hour. (but yeah, the hoses would be an eaisier fix ) -------------------- CLOSED on 25 acres! -shop coming soon.... |
Oct 5, 2007 - 11:00 AM |
Enthusiast Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
Check fluid level, tstat, rad cap. Check the easy ones first before the more expensive stuff.
Oct 5, 2007 - 6:21 PM |
QUOTE(99GT @ Oct 5, 2007 - 10:00 AM) [snapback]602031[/snapback] Check fluid level, tstat, rad cap. Check the easy ones first before the more expensive stuff. turns out there was a crack in the radiator. i just couldn't see anything last night cuz how dark it was. as soon as i opened the hood the crack was as clear as day. thanks for the input though. ended up dropping in a koyo radiator. not too complicated at all. -------------------- |
Lo-Fi Version | Time is now: December 2nd, 2024 - 6:21 AM |
