> O2 Sensor trouble, cant get it off!
post Oct 14, 2007 - 8:23 PM
jussten
Joined Oct 31, '03
From Phoenix, Az
Hey guys, I have had a little trouble replacing my 2nd oxygen sensor... actually its the removal I'm having issue with. First I tried just wrenching it, no luck. Then I bought an oxygen sensor wrench to use with a ratchet, still no luck. Tried soaking the threads with PB Blaster and hitting the wrench with a hammer to turn it counter clock wise but it wont budge at all. Has anyone else had trouble getting this off or any suggestions?
post Oct 14, 2007 - 8:37 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
they make special o2 sensor deep impact sockets
post Oct 14, 2007 - 9:06 PM
1bwilson
Joined Aug 30, '02
From Maryland
Cheater bars are your friend, also you can melt a crayon into the threads to bust it loose. Works decently but makes a hell of a mess. Also Im not sure how great of a idea the crayon is with a sensor.
Member of Team 5sfTe
post Oct 14, 2007 - 9:18 PM
heat the pipe and sensor up, it'll ruin the sensor but you're replacing it anyways.
post Oct 25, 2007 - 12:16 PM
jussten
Joined Oct 31, '03
From Phoenix, Az
ended up having to take it to a shop, they had to remove the radiator and cut the sensor in half.... then drill it out. that thing was tough.
Lo-Fi Version Time is now: November 27th, 2024 - 11:26 AM
