Best transmission fluid? |
Nov 16, 2007 - 7:37 PM |
Enthusiast Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
I'd like to replace the transmission fluid in my car, and I've heard that synchromesh is very good for the Celica's transmission, plus it will get rid of any grinds (which I have a 3rd gear grind). Other then that, any other suggestions to what I can use?
BTW, is there any other way to fill up the transmission besides filling it in the side hole? -Matt |
Nov 17, 2007 - 7:47 PM |
Enthusiast Joined Feb 27, '07 From Jacksonville Currently Offline Reputation: 0 (0%) |
I used syncromesh. I didn't notice a difference, but mine's smooth. I'd say go for it.
And no, that side plug is the only way. -------------------- 1997 Limited Edition Vert (((SOLD))) |
Nov 17, 2007 - 8:03 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
to be correct the stuff you put in the manual transmission is actually called gear oil. transmission fluid is the stuff that goes into the automatic tranny's.
The side plug is the only way. Its not like its hard, its like changing your oil. Just make sure you get the pump to pump the gear oil into your tranny, instead off having one of those bottles with the nose on them and you have to squirt from the bottle. IMO it works like crap. -------------------- 98 Celica gt red- totaled deer
Dec 6, 2007 - 12:37 AM |
Sorry to bump an old thread, but I'd like to change my transmission fluid soon. Once the fluid is all drained, and if I don't have a pump, could I just pour each bottle into the transmission through the nozzle?
And it's about 3.5 quarts, right? |
Dec 6, 2007 - 3:05 AM |
you won't have enough room if you're pouring it straight from the bottle (at least i didn't).. i used a funnel that has a flexible hose to the end of it.
and it's 2.6 quarts for a refill btw This post has been edited by azian_advanced: Dec 6, 2007 - 3:06 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Dec 6, 2007 - 3:39 AM |
QUOTE(azian_advanced @ Dec 5, 2007 - 10:05 PM) [snapback]620144[/snapback] you won't have enough room if you're pouring it straight from the bottle (at least i didn't).. i used a funnel that has a flexible hose to the end of it. and it's 2.6 quarts for a refill btw reallly???? mines was 3.75qts. oh and on another note........make sure the axle and tranny seals are perfect........cuz i just spent $45 on synchroMax made by royal purple........now its leaking from my axles...........sucks ballz -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 6, 2007 - 9:22 AM |
yeah, you're probably right, i got the info for an AT, not MT. my bad
anyway, it should show the fluid capacity near the end of the handbook. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Dec 8, 2007 - 2:35 AM |
Enthusiast Joined Nov 4, '06 From POLAND Currently Offline Reputation: 0 (0%) |
What oil use for gearbox with LSD (S54+LSD)
TRD recommended some special oil :TRD LSD oil FF Anyone have experiences ??? -------------------- BEAMS swaped .......
Dec 8, 2007 - 3:53 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
QUOTE(pasqual @ Dec 8, 2007 - 8:35 AM) [snapback]620849[/snapback] What oil use for gearbox with LSD (S54+LSD) TRD recommended some special oil :TRD LSD oil FF Anyone have experiences ??? TRD sells a LSD for the S54 tranny?? -------------------- JDM Powerplant installed, BPU coming very soon!
Dec 8, 2007 - 4:19 PM |
QUOTE QUOTE(pasqual @ Dec 8, 2007 - 8:35 AM) * What oil use for gearbox with LSD (S54+LSD) TRD recommended some special oil :TRD LSD oil FF Anyone have experiences ??? TRD sells a LSD for the S54 tranny?? Yes ... I have 3s-ge BEAMS .. but you can install LSD in any S54 .... -------------------- BEAMS swaped .......
Dec 11, 2007 - 11:39 PM |
Enthusiast Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
just fyi, it's 2.6 on flat ground, if it's on jackstands it won't start leaking out until about 3.25 qts, just from my recent experience
Lo-Fi Version | Time is now: January 9th, 2025 - 11:58 PM |
