> AFM PART #'S
post Nov 18, 2007 - 7:36 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
I need a new Air flow meter. Im being told that a turbo supra has the same AFM as the 3sgte. Is this true? Does anyone have a list of interchangable part #'s for the 2nd generation AFM? I want to be sure I get the correct one. I bought one a few months back(from someone on this sight) and it was definetly NOT the correct one! The part # on that one was convienently scratched off and painted over.. mad.gif
Anyways, any help would be appriciated. Thanks
-Brian
post Nov 18, 2007 - 8:37 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
The part# of the one I have is 22250-74170
post Nov 18, 2007 - 8:41 PM
dont get one from a supra or rx7 or some other car. only use one from a 90-93 alltrac/mr2.
whats wrong with the one you have right now?
post Nov 19, 2007 - 7:28 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(lagos @ Nov 18, 2007 - 8:41 PM) [snapback]615442[/snapback]
In 30* weather I go into low boost mode. It was going into LBM on hot days until I moved the MAF away from my engine bay. I had a maf from a N/A vehical. I tried to switch the temperature sensor with the alltrac MAF I have. I screwed up the circuit board when I tried to solder the connections back together. Its been apart before I had it. These arent made to come apart! Now I know why! biggrin.gif
This post has been edited by toyotacrazy: Nov 22, 2007 - 6:56 PM
Lo-Fi Version Time is now: November 27th, 2024 - 10:24 AM
