> Exhaust
post Dec 20, 2007 - 4:47 PM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
I´m after some aftermarket performance exhaustsystem to my 3S-GE. I´ve been looking for a while, but the only reaseonable I´ve found is Apexi N1. I also ran into HKS exhausts, but they were too expensive. Any suggestions?
Thanks allready mates.
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
post Dec 20, 2007 - 5:29 PM
94_c3lica_gt
Joined Aug 30, '07
From Oak, Ridge NJ
I've been looking for an exhaust system for my car so that when i do my 3sgte swap, the turbo will breathe better. Where did you find the apexi n1 turbo for the 6gc? or the hks? THANKS!
post Dec 22, 2007 - 1:04 PM
Penkka
Joined Dec 20, '07
My Celica doesn´t have a turbo, its N/A 2.0.
post Dec 22, 2007 - 1:12 PM
Kadett
Joined Mar 17, '05
From The Netherlands
The only one's I know off are:
Apexi
HKS
Kakimoto
C-one
post Dec 22, 2007 - 1:33 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
Or you could just go custom, it might cost less since the exhausts that fit our cars would have to be shipped. Find an exhaust shop and get a quote.
post Dec 23, 2007 - 12:12 PM
Penkka
Joined Dec 20, '07
QUOTE(GTS13 @ Dec 22, 2007 - 1:33 PM) [snapback]625036[/snapback]
Yea I´ve been thinking about that too, but wich ones better, with a 2.25" bore or 2.5"?
This post has been edited by Penkka: Dec 23, 2007 - 12:13 PM
post Dec 23, 2007 - 12:31 PM
Kadett
Joined Mar 17, '05
60mm is the Size that all Japanese companies used. I would use the same.
post Jan 4, 2008 - 5:58 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
60 mm equates to 2.362in which is inbetween 2.25 and 2.5in. So, which is better?
post Jan 6, 2008 - 8:05 AM
Penkka
Joined Dec 20, '07
If I´ve understood correctly, 2.5" looses the highpowers, but is more torguebased. the 2.25" instead gives you more power to higher revs, correct?
post Jan 6, 2008 - 2:15 PM
99Celica
Joined Nov 1, '07
"If I´ve understood correctly, 2.5" looses the highpowers, but is more torguebased. the 2.25" instead gives you more power to higher revs, correct?"
can anyone answer this? Also do one of these sound ricey? I'm ready to go to the shop but I can't decide what size.
post Jan 18, 2008 - 2:40 AM
Teksi
Joined Aug 26, '07
From Finland
QUOTE(Penkka @ Dec 20, 2007 - 4:47 PM) [snapback]624560[/snapback]
Hei Penkka!
I have used hks super drager coming from japan. It's 60mm and it will be for sale...
I can also get other exhaust from japan if you want.
Lo-Fi Version Time is now: December 1st, 2024 - 3:08 PM
