> 3sgte halftrac clutch question
post Jan 10, 2008 - 8:13 PM
02bluerolla
Joined Aug 31, '05
From Houston TX
hey waz up guys.. well there selling me a clutch kit for a halftrac ( bascillayis a 91 celica with a 91 gt tranny with a 2nd gen 3sgte) well my question is will i be able to use the clutch in my 94 gt tranny and 2nd gen 3sgte engine.
post Jan 11, 2008 - 3:44 PM
95st-celica
Joined Mar 29, '07
From Philly
prolly not becaus i think they differ a little bit in the style and shape of the trans and what not...not a 100% but i dont think you can
1988 Dodge Aries K (sold)
post Jan 11, 2008 - 4:55 PM
If your using the ST185 3SGTE with the S53 transmission you will need the 3SGTE pressure plate and flywheel with the 5SFE clutch disk.
post Jan 11, 2008 - 6:21 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
What he said. Ideally you would use a custom clutch with a 3SGTE disc and the hub to fit the GT tranny. We stock these clutches in any stage, stage 1 to stage 5, and the prices are good too. Let me know if you need one.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jan 11, 2008 - 7:06 PM
act, spec, or any of the clutch comapanys should be able to make you the clutch setup you'll need.
it will be a 3sgte pressure plate, and 3sgte clutch disk, with the s54 spline.
post Jan 11, 2008 - 8:20 PM
Dr_Tweak
Joined Mar 31, '04
Yeah except that if you get one from Spec it will shatter on you and they won't do anything about it except give you another, which also will shatter, and then another one, and then....
post Jan 11, 2008 - 11:30 PM
QUOTE(Dr_Tweak @ Jan 11, 2008 - 8:20 PM) [snapback]630137[/snapback]
I think that was an issue with the stage2's. They ended up redesigning it because of it.
Ive had my stage3 for about 2-3yrs now without problems.
post Jan 12, 2008 - 1:47 AM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(lagos @ Jan 11, 2008 - 8:30 PM) [snapback]630157[/snapback]
after doing tons of reading on how the stg 2 spec hybrid clutch disc would break i went with a stg 3
i had a sprung hybrid stage 3 from spec for a like 6 months and the springs on the sprung disc wore out the metal pieces which held them into place... this caused a large problem. After doing some research this problem i found that this is common among all sprung clutches whose drivers tend to down shift to slow, have short gears, drive a bit aggressively, and tend to back on and off the gas.
i am currently using a unsprung clutch disc (spec did replace it) and it has done fine so far... no chatter... i dig the engagement tons more and it also has allowed me to hon my heal toe shifting; coupled with my LSD helical diff from an MR2 spyder its a very very nice combo...
This post has been edited by urbandork: Jan 12, 2008 - 1:47 AM
post Jan 12, 2008 - 3:55 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE(presure2 @ Jan 11, 2008 - 2:06 PM) [snapback]630115[/snapback]
doesnt the ACT clutch tear up the 5sfe tranny??? from what i heard.
post Jan 12, 2008 - 6:54 AM
QUOTE(808celica @ Jan 12, 2008 - 3:55 AM) [snapback]630202[/snapback]
ive had my act clutch in my car for over 3 years now.
i've never had a problem with it, ever.
post Jan 12, 2008 - 6:22 PM
Its not about one brand being good or bad. ACT, Spec, Clutch Masters, Centerforce, etc...etc... etc... all sell different types of clutches. Some are more aggressive then others and some even have problems. If you google almost any brand, you'll find a forum full of people who have something bad to say about almost every clutch brand out there.
Act sells a very mild street disk, and they also sell some very heavy duty puck clutches. So you cant just say that all Act clutches are good/bad.
This post has been edited by lagos: Jan 12, 2008 - 6:22 PM
post Jan 16, 2008 - 1:15 AM
6strngs
Joined May 12, '06
From Wilmington, NC
I'm pretty sure Spec did redesign their stage 2, cause I've had mine in for quite a while now with no problems.
post Jan 16, 2008 - 11:50 AM
jcbass7
Joined Apr 20, '06
From Florida
http://www.6gc.net/forums/index.php?showto...069&hl=spec
thats the info you need to order a spec clutch for a 3sgte with the s54 tranny
I had a spec stage two and loved it, no problems
Lo-Fi Version Time is now: January 11th, 2025 - 1:22 AM
