> Air/Fuel gauge freakin out, cuz i wired it wrong??
post Jan 20, 2008 - 2:09 PM
Redline08
Joined Feb 23, '07
From Albany, NY
So i just hooked up an air/fuel gauge to the O2 sensor coming right off the headers. Im guessin this wasnt the best place to wire it because it jumps back and forth from lean to rich constantly unless i go WOT then it just shoots into rich and stays there until i let off.
Wheres the best place to wire it? prolly off the ECU?...
post Jan 20, 2008 - 2:16 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Redline08 @ Jan 20, 2008 - 7:09 PM) [snapback]632624[/snapback]
On a basic narrowband O2 sensor... that's typically what it'll do.
post Jan 20, 2008 - 2:24 PM
Redline08
Joined Feb 23, '07
From Albany, NY
it typically bounces back and forth like a retard?
post Jan 20, 2008 - 2:39 PM
Jeunesse
Joined Aug 21, '07
From Toronto
"One thing to make sure of though is when you connect the o2 signal wire, tap into the main harness wire, not the o2 sensor wire. The o2 sensor wire has a small hole in it so that it can take a reading of the outside air to compair it to the amount of air in the exhaust, if you tap into that wire, your o2 will give off a false reading and it will screw up your A/F ratio. " - Valo666
"And on Deceleration... Your car is automatic, so when you are on the brakes, the torque converter unlocks, and the idle valve bumps up the idle, thus, your engine is no longer in decel mode. When your engine is at a higher RPM with no throttle and no brake, it is in decel mode, aka deceleration fuel cut. During this time, your injectors are fully shut off (zero duty cycle), so your O2 sensor is not registering any fuel in the exhaust stream. What you are seeing is absolutely normal.
Narrowband AFR gauges are also a universal item, so any differences with O2 sensors (ie: GM, Toyota, Honda, etc) will react differently with the gauge.
It's nice to see what your engine is doing, but the nature of this gauge is very inconsistent so don't worry about it too much. wink.gif" - Tony_the_Tiger
This post has been edited by Jeunesse: Jan 20, 2008 - 3:11 PM
-Derick
"In hoc signo vinces." In this sign thou shalt conquer."
Gone but never forgotten....
post Jan 20, 2008 - 2:42 PM
Redline08
Joined Feb 23, '07
From Albany, NY
damn nice response lol. I tapped into the wire after the connector, not the wire coming right off the sensor so im guessin im all good.
Thanks!
post Jan 20, 2008 - 3:39 PM
all that is good for is a cool light show.
post Jan 20, 2008 - 4:08 PM
QUOTE(Redline08 @ Jan 20, 2008 - 2:24 PM) [snapback]632631[/snapback]
thats how they work. the bouncing is meant to show you that the car is running in closed loop mode and that your o2 is working correctly.
post Jan 20, 2008 - 7:59 PM
stetsonaw
Joined Aug 3, '07
From Bellevue, Nebraska
my autometer phantom does the same thing, so annoying.
~Andy
Check out my Droid Goodies
| My Flickr
post Jan 20, 2008 - 11:06 PM
wrathc5525
Joined Oct 30, '07
From hudson falls ny
according to my teacher it is supposed to do that because the pcm is constantly trying to keep a stoichiometric air to fuel ratio of 14.7-1. so the pcm use's the o2 sensor's reading to see how much air is in the exhaust system. if there is not a lot then the system is rich and then the pcm narrow's pwm of the fuel injector solenoids so its sprays less fuel which means more air in the exhaust which makes it go lean. so it is always changing to compensate for a 14.7-1 ratio
post Jan 20, 2008 - 11:07 PM
sounds like you thought you would be seeing a wideband output which will still bounce around but not as much.
post Jan 24, 2008 - 5:12 PM
6G96GT
Joined Jan 20, '08
From East Coast
so why wouldn't you just go with a wideband kit and then tune it correctly for the proper A/F?
post Jan 24, 2008 - 5:49 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(6G96GT @ Jan 24, 2008 - 2:12 PM) [snapback]634140[/snapback]
cause widebands cost about $200+ more than just a narrowband. but it definately is the only way to get an accurate reading of your A/F ratio.
Lo-Fi Version Time is now: December 2nd, 2024 - 11:19 AM
