which 3S MAP Sensor, rev 2 or rev 3 |
Feb 8, 2008 - 1:22 PM |
Enthusiast Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) |
hey all.
I am just about to boost my 7a, as many of you know. Anyway, I have managed to source sensors from the 3S, but what would work or does it not matter. He has both rev 2 and rev 3. Only posting here because i need to make a quick decision. Cheers Jason. |
Feb 8, 2008 - 2:39 PM |
Enthusiast Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
idk but ppl say we need a 3sgte map sensor on are 7afte or your engine will blow, i tuned my emanage with my stock map sensor and the car runs great, but when i put my 3sgte map sensor the car just chokes on air when your giving it throtle.... any one no why?
Feb 8, 2008 - 3:08 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
different signals you have to retune to use the 3s map
rev 3 doesn't have a map i don't think -------------------- |
Feb 8, 2008 - 3:28 PM |
ah ok thanks. I am running a SAFC2, but will use emanage at some point. So I guess I'll go for the rev 2. Also, will it just plug in or do I need the plug as well?
Many thanks. |
Feb 8, 2008 - 5:20 PM |
Enthusiast Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
jus use check valves for the map
Feb 8, 2008 - 6:42 PM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
This isnt 1991. Check valves should not be on your damn vehicle
Feb 8, 2008 - 6:46 PM |
lol. true that LAFF. I decided to go for the rev 2 sensor. Will it just plug into my harness?
Feb 9, 2008 - 6:42 AM |
QUOTE(mikecelica @ Feb 8, 2008 - 5:20 PM) [snapback]639521[/snapback] jus use check valves for the map check valves are for fish tanks, not turbo setups. use the 2 bar map from a rev 2 3s funky, (yes, it is plug and play.) you'll be just fine if you set it up and tune it properly. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Feb 9, 2008 - 8:22 AM |
ohh i see, then i guess i gota go pick one up too... whats rev 2 , u mean generation 2 3sgte? so from like a 90-93 all-trac or 90-94 mr2 turbo? is that right?
Feb 9, 2008 - 10:43 AM |
QUOTE(mikecelica @ Feb 9, 2008 - 8:22 AM) [snapback]639688[/snapback] ohh i see, then i guess i gota go pick one up too... whats rev 2 , u mean generation 2 3sgte? so from like a 90-93 all-trac or 90-94 mr2 turbo? is that right? yes. -------------------- Former Team 5SFTE pro member ;)
Feb 9, 2008 - 11:46 AM |
thanks guys. I will keep yo updated. I'm using a JSGTools manifold kit and T25. Lets see how it goes.
I havent got a wideband in the car, but the workshop does have a rolling road which i used to set up several SAFC2's and Neos. I will later change to emanage. This is just the beginning. |
Feb 9, 2008 - 3:21 PM |
im running 8psi on my stock map sensor, i tune my emanage with it and the car running great. but im a put th 3sgte map sensor to get the most power i can from my engine, but im a have to retune it.i think if you get a good tune you can run with your stock map sensor.
Feb 9, 2008 - 5:28 PM |
i thoguht stock couldnt read boost? it reads -15 to 0. right?
Feb 9, 2008 - 7:10 PM |
correct Mike. It reads vacuum. I think the emanage can manipulate this, though not 100% sure. I'm just gonna do the right thing by fitting a proer MAP sensor.
Lo-Fi Version | Time is now: November 27th, 2024 - 11:48 PM |
