Put a 4AGE head in 7AFE !! Need info |
Feb 26, 2008 - 9:26 PM |
Enthusiast Joined Feb 26, '08 From Portugal Currently Offline Reputation: 0 (0%) |
Hello!
First of all i glad to find this amazing forum. Well i got a Celica 1.8 ST 1995 7AFE, and i got 4AGE motor from a friend. I read is possible to change the head of 7AFE to a 4AGE head! But i have some doubts... 1. What gains can be expect? 2. the change is straigth ?? No need to change anything ? Is just bolt the 4AGE head on 7AFE block ? ....If not what i need to put from the 4AGE motor in 7AFE ? 3. Do i need the 4AGE ecu to run this ? Thanks so much This post has been edited by elastikman: Feb 26, 2008 - 9:28 PM |
Feb 26, 2008 - 9:41 PM |
Enthusiast Joined Mar 11, '06 From Way South Chicago Currently Online Reputation: 0 (0%) |
search up 7age on google and you'll learn ALOT.
Feb 26, 2008 - 9:56 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
4a ecu and more, the engine sticky has some good info on this.
-------------------- JDM guy made me do it.
Feb 26, 2008 - 10:15 PM |
Enthusiast Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
You can even contact Nik on this forum about the 7age.
Feb 27, 2008 - 6:23 PM |
Hi!
I pass my day reading stuff about 7AGE. I learn a lot of this... So to simplify part list is: - 4AGE head (small port or big port) - 4AGE pistons -Timing belt Porsche 924 - 4AGE ECU Do i miss something?? |
Feb 27, 2008 - 6:46 PM |
Enthusiast Joined Nov 21, '07 From I-59 -N- 610 Houston, Tx Currently Offline Reputation: 0 (0%) |
what 4age are you goin to use, ii was actually thinkking of doing it in a prism 91 gsi with a red top...
Feb 27, 2008 - 6:54 PM |
http://www.6gc.net/forums/index.php?showto...31&hl=7agte
there is alot of info in there and there are a few ways to do it this is just the way i did mine -------------------- yea your 3sgte is cool but ill stick to my 7agte
Feb 28, 2008 - 12:07 AM |
QUOTE(monkey @ Feb 27, 2008 - 3:46 PM) [snapback]646711[/snapback] what 4age are you goin to use, ii was actually thinkking of doing it in a prism 91 gsi with a red top... Red Top and Blue top are not real good definitions I own 2 red tops an 88 large port TVIS and a 91 small port. The 91 prizm should be a small port as well. -------------------- JDM guy made me do it.
Mar 3, 2008 - 6:23 PM |
Enthusiast Joined Mar 3, '08 From BP, MN Currently Offline Reputation: 0 (0%) |
1. at least 30-40hp gains
2. nope. longer throttle cable and wirings a bitch. 3. u should if u want to take advantage of vvt and the better MAP. assuming ur using a 20v bt This post has been edited by 20v_celica: Mar 3, 2008 - 6:26 PM |
Mar 11, 2008 - 10:52 PM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
QUOTE(elastikman @ Feb 27, 2008 - 6:23 PM) [snapback]646698[/snapback] Hi! I pass my day reading stuff about 7AGE. I learn a lot of this... So to simplify part list is: - 4AGE head (small port or big port) - 4AGE pistons -Timing belt Porsche 924 - 4AGE ECU Do i miss something?? wiring? I do know distirbutor will give u problem otherwise s/alone ecu This post has been edited by normality78: Mar 11, 2008 - 11:04 PM |
Lo-Fi Version | Time is now: November 23rd, 2024 - 11:59 AM |
