> 3s pressure plate again, What works.
post Mar 2, 2008 - 1:20 PM
6g25th
Joined Nov 28, '05
So, i've posted a couple times about this whole pressure plate thing and one preson said that IIRC is the same thing, but unfortunately I don't know what IIRC stands for. I assume that he means that a 90-93 act pressure plate would work on a 95' 3s. Does anyone know if this is true?
post Mar 3, 2008 - 5:49 PM
scothaniel
Joined May 1, '03
From Michigan
IIRC = If I Remember Correctly.
And yes, the 90-93 ACT pressure plate for the 3SGTE will work with the 95 3SGTE. I'm running one on my 3rd gen motor.
This post has been edited by scothaniel: Mar 3, 2008 - 5:51 PM
Scott
West Michigan
post Mar 4, 2008 - 5:37 PM
phattyduck
Joined Dec 5, '05
From LA, CA
I also have a '95 JDM 3s-gte with a 90-93 Fidanza flywheel with Spec pressure plate and Clutchnet 6-puck clutch. I think the only difference between the 2nd and 3rd gen flywheels is a slight change in the flywheel ring gear tooth pattern (I believe the later 3s-gte had more teeth on the flywheel and a slightly redesigned nose on the starter). My 3rd gen starter works just fine, but makes a little squeak noise when I start the car.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: February 23rd, 2025 - 9:17 PM
