> What's our stock compression...
post Apr 10, 2008 - 4:07 PM
6G96GT
Joined Jan 20, '08
From East Coast
How much compression can our 5sfe cyl-head handle as far as pistons and decking are concerned? I can't decide on 9:1, 10:1 or higher?
This post has been edited by 6G96GT: Apr 10, 2008 - 4:07 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I think stock compression ratio is 9.5:1
post Apr 10, 2008 - 4:10 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE(6strngs @ Apr 10, 2008 - 4:07 PM) [snapback]663316[/snapback]
True
10:1 will be fine if you use 93 octane - I'm not sure but I know I wouldn't run it on 87
This post has been edited by DEATH: Apr 10, 2008 - 4:10 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 10, 2008 - 4:11 PM
QUOTE(6G96GT @ Apr 10, 2008 - 5:07 PM) [snapback]663315[/snapback]
stock is 9.5:1
you can get it a bit higher by milling the head for a few more na HP, but if your wanting to turbo down the road, i would go 9:1 or the stock 9.5:1 at the most.
post Apr 10, 2008 - 4:30 PM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE(presure2 @ Apr 10, 2008 - 4:11 PM) [snapback]663320[/snapback]
stock is 9.5:1
No turbo at for me...so what would you choose for an option then for comp. ratio? I would like to deck the head like you mentioned (not too much though)...
thanks guys!
post Apr 10, 2008 - 5:55 PM
i would go 10.5:1 max, using 93 octane, minimum.
post Apr 10, 2008 - 7:07 PM
6G96GT
Joined Jan 20, '08
From East Coast
QUOTE(presure2 @ Apr 10, 2008 - 5:55 PM) [snapback]663368[/snapback]
10.5:1 - is that your max "safe" point? I want the max, but in the "safe" zone. What's after 93 octane? Racing Fuel?
Thanks!
post Apr 11, 2008 - 9:50 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE(6G96GT @ Apr 10, 2008 - 7:07 PM) [snapback]663396[/snapback]
Thanks!
Yeah but you should be fine if your tuned right and only ever use 93. That combination will make a big improvement in power too, especially if you do the cam upgrade and all the other little things you've been talking about. Do it - build an N/A monster man biggrin.gif
EXT: WRC/TRD/404
post Apr 11, 2008 - 6:50 PM
6G96GT
Joined Jan 20, '08
From East Coast
Thanks Guys! Will do my best, "safely".
post Apr 12, 2008 - 7:34 AM
QUOTE(DEATH @ Apr 11, 2008 - 10:50 AM) [snapback]663572[/snapback]
Thanks!
its been done.
research the name "jim snoodgrass"
he made ~147whp, with engine management and all, shaved head, valve job, and one cam (exhaust IIRC)
i would expect ~5-10whp more with the newer electronics, and newer motor. (his was a mr2 "5th gen celica equivlent" motor)
post Apr 12, 2008 - 11:32 AM
6G96GT
Joined Jan 20, '08
From East Coast
one cam, so one was left stock? Do I look him up on google? Thanks for the info!
Lo-Fi Version Time is now: January 10th, 2025 - 7:14 PM
