> Car not starting! Help!
post Apr 10, 2008 - 11:00 PM
Cexlica
Joined Jul 17, '07
How can you tell if your timing belt has broken? Will the car act like normal? or will the car run really crappy if the timing belt is broken?? 1996 Celica 7afe, The car has Air, has Spark, the only thing is I think the timing belt is broken, but prior to the car not starting, the car was driving perfect EXCEPT a check engine light.
One more thing, where is the fuel pump fuse?? If not a broken timing belt, I'm thinking it could be the fuel pump fuse, but where is it located?
The car is cranking, just not starting, battery and alternator is fine, starter is fine. Any help would be appreciated, thanks!
Car is at my work place and need to get it running a.s.a.p, thanks!
This post has been edited by Cexlica: Apr 10, 2008 - 11:01 PM
post Apr 10, 2008 - 11:39 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Maybe your fuel pump is out. Thats what happened to me and silly me I thought the timing belt broke. Just check to see if your fuel pump is out.
94 Celica gt white (sold)
post Apr 11, 2008 - 12:02 PM
D-Man
Joined Jan 18, '08
From Houston
x2 i just replaced a fuel pump, had a hole in it'd diaphragm. it happends~ i'd roll my dice at that, remove the line and see if it shoots out fuel when attempting to start it.
Damn D-Man - most impressive.
post Apr 11, 2008 - 12:11 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
uh, what was the CEL code?
I don't think the engine would crank if your timing belt was broken, IIRC
post Apr 11, 2008 - 12:12 PM
D-Man
Joined Jan 18, '08
From Houston
what is IIRC?
post Apr 11, 2008 - 7:50 PM
Cexlica
Joined Jul 17, '07
^IIRC stands for If I recall correctly and/or If I remembered correctly
Update: It is NOT the fuel pump, I have narrowed it down to 3 things, Fuel Filter, Clogged Injectors, Fuel pump relay fuse. <---Where is the fuel pump relay located in the fuse box???
Timing belt is fine.
post Apr 11, 2008 - 10:02 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Look under the fuse box cover. It should tell you where it is.
post Apr 13, 2008 - 9:00 PM
Cexlica
Joined Jul 17, '07
I found the EFI relay, it's black, right? How do I tell if it needs replacing? It looks like all the wires are still entact.
Anyways, I just changed the fuel filter, and the car still does not start. I am completely stumped, i have no idea what is wrong now, the only thing i could think of are clogged injectors. But, the car was driving fine prior to not starting, shouldn't clogged injectors make the car run really crappy? Well, the car was driving fine before this happened.
Once again, the fuel pump is working, fuel filter changed, timing belt is ok, air filter is ok, spark is ok, efi relay looks ok, battery is good. Car cranks but wouldn't start.
No idea what the CEL could be, car was driving excellent even with the CEL came out, which was about 2 weeks before the car didn't start. Thanks!!
This post has been edited by Cexlica: Apr 13, 2008 - 9:02 PM
post Apr 13, 2008 - 9:57 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
It could be your ignitor. I honestly don't think that your injectors are clogged to the point that the car won't start. You won't be able to tell if your relay is good or bad. You can find someone with a celica and use their relay and see if the car fires up. If you find out that that didn't help, it has to be something electrical. If the car was running fine before and all of the sudden decided to stop, I don't know. Take off the distributor and take the ignition control module to autozone and have them check out the ohms on that thing.
post Apr 14, 2008 - 1:53 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
what year is your car man?
post Apr 14, 2008 - 11:40 AM
mr-belowaverage
Joined Feb 4, '07
From Ontario, Canada
Spray something combustible into the intake plenum and see if it catches for a minute. Check the fuel rails for pressure to rule out delivery.
post Apr 14, 2008 - 12:12 PM
GriffGirl
Joined Feb 7, '07
Changing your fuel filter would not enable your car to start. I can't possibly imagine a fuel filter that could be so clogged that your car wouldn't start to begin with.
It sounds like you have an ignition problem. My bet would be a bad ignitor coil, dead distributor, or near-dead starter. Something like that. I'm not a mechanic though.
What does your car sound like when you try to start it? Does it sound normal, but just doesn't catch? Or is there any kind of grinding sound?
post Apr 14, 2008 - 2:31 PM
D-Man
Joined Jan 18, '08
From Houston
QUOTE(mr-belowaverage @ Apr 14, 2008 - 11:40 AM) [snapback]664430[/snapback]
It's easyer to trouble shoot a problemed car that is spread across a few miles, because you know what you'll need.
A new car.
post Apr 14, 2008 - 3:24 PM
Cexlica
Joined Jul 17, '07
The car is in the shop at the moment, funny thing is the mechanic cranked it up and knew exactly what it was. I was like WTF, I was worrying for a whole week what the problem was, and here it took you 2 seconds to find the problem, lol.
It turns out to the the timing, the timing belt is still intact, but it jumped a couple teeth.
post Apr 14, 2008 - 3:32 PM
D-Man
Joined Jan 18, '08
From Houston
oh, i hate when that happens... i sold a car because of that one time; when i was younger... only got like $150 bucks for it though frown.gif for the shape of the car, i was actualy happy biggrin.gif laugh.gif biggrin.gif
post Apr 14, 2008 - 4:03 PM
cochise
Joined Nov 14, '06
From michigan
QUOTE(Cexlica @ Apr 14, 2008 - 8:24 PM) [snapback]664498[/snapback]
If it jumped once it will do it again. replace the belt and check the timing gears also. If they are worn replace them.
Lo-Fi Version Time is now: November 26th, 2024 - 1:55 AM
