Replaced radiator and rod bearings |
Apr 13, 2008 - 3:41 AM |
Enthusiast Joined Feb 19, '08 From Anaheim,CA Currently Offline Reputation: 2 (100%) |
I just got my car back from the mechanic. He replaced the radiator and the rod bearings. Everything seems to be running fine except when I take off in 1st gear. I can feel the pedals and and seat shake and the car seems to struggle taking off. It only happens for 2 seconds. Do you guys think it might be the clutch or something he did while replacing the rod bearings?
This post has been edited by BeefyT: Apr 13, 2008 - 5:46 AM -------------------- lol
Apr 13, 2008 - 9:21 AM |
Enthusiast Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
Just to be sure, I'd check the injectors for any blockage, also check your motor mounts for wear, and possible check your timing...maybe the mech. advanced it a bit too much. I'd might check your intake hoses and pipes from the airmeter back to the throttle body to make sure everything's hooked up right and not loose or even disconnected.
Apr 13, 2008 - 11:23 AM |
he replaced the rod bearings? and only the rod bearings? wtf mate. if your engine was damaged enough to need new rod bearings then odds are the crank should have been taken out, mic'd, turned, polished, and while you're at it do the main bearings as well.
thats like putting a plug in a bald tire, sure it works but you need a new tire. understand what i'm saying? i hate when shops just go for the quick and easy fix rather than doing it right. it makes me sound bad when i tell someone they need an engine because they have rod knock and they say 'well the shop down the road can do the rod bearings for $500 instead of the whole engine'. plugging a bald tire. -------------------- |
Apr 13, 2008 - 12:18 PM |
QUOTE(Bitter @ Apr 13, 2008 - 11:23 AM) [snapback]664116[/snapback] he replaced the rod bearings? and only the rod bearings? wtf mate. if your engine was damaged enough to need new rod bearings then odds are the crank should have been taken out, mic'd, turned, polished, and while you're at it do the main bearings as well. thats like putting a plug in a bald tire, sure it works but you need a new tire. understand what i'm saying? i hate when shops just go for the quick and easy fix rather than doing it right. it makes me sound bad when i tell someone they need an engine because they have rod knock and they say 'well the shop down the road can do the rod bearings for $500 instead of the whole engine'. plugging a bald tire. Here's a scenerio for ya...if you ran a compression test on your block which is stock with 172K and the test ran a near perfect reading AND you don't burn oil, leak oil, or smoke at all...would you consider going into the bottom end and replacing the bearings "just because" of the high mileage? ... or would you leave it alone? I'm only asking cause that's my situation. SORRY TO INTRUDE ON THE POST!!! |
Apr 13, 2008 - 1:00 PM |
Enthusiast Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
QUOTE(6G96GT @ Apr 13, 2008 - 5:18 PM) [snapback]664129[/snapback] QUOTE(Bitter @ Apr 13, 2008 - 11:23 AM) [snapback]664116[/snapback] he replaced the rod bearings? and only the rod bearings? wtf mate. if your engine was damaged enough to need new rod bearings then odds are the crank should have been taken out, mic'd, turned, polished, and while you're at it do the main bearings as well. thats like putting a plug in a bald tire, sure it works but you need a new tire. understand what i'm saying? i hate when shops just go for the quick and easy fix rather than doing it right. it makes me sound bad when i tell someone they need an engine because they have rod knock and they say 'well the shop down the road can do the rod bearings for $500 instead of the whole engine'. plugging a bald tire. Here's a scenerio for ya...if you ran a compression test on your block which is stock with 172K and the test ran a near perfect reading AND you don't burn oil, leak oil, or smoke at all...would you consider going into the bottom end and replacing the bearings "just because" of the high mileage? ... or would you leave it alone? I'm only asking cause that's my situation. SORRY TO INTRUDE ON THE POST!!! compression and leaking oil has nothing to do with your bearings. all you HAVE to take off is the oil pan. if it has a knock, i would -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Apr 13, 2008 - 1:15 PM |
QUOTE(Bitter @ Apr 13, 2008 - 11:23 AM) [snapback]664116[/snapback] he replaced the rod bearings? and only the rod bearings? wtf mate. if your engine was damaged enough to need new rod bearings then odds are the crank should have been taken out, mic'd, turned, polished, and while you're at it do the main bearings as well. thats like putting a plug in a bald tire, sure it works but you need a new tire. understand what i'm saying? i hate when shops just go for the quick and easy fix rather than doing it right. it makes me sound bad when i tell someone they need an engine because they have rod knock and they say 'well the shop down the road can do the rod bearings for $500 instead of the whole engine'. plugging a bald tire. well he was just going to replace the radiator but he heard the engine was knocking so he just replaced the rod bearings so i wouldnt hear the knock. He told me the crank isnt damaged that bad. All he charged me was $250 US. He also did and oil change and replaced the spark plugs. Im gonna have the engine rebuilt soon. -------------------- lol
Apr 13, 2008 - 2:18 PM |
QUOTE(BeefyT @ Apr 13, 2008 - 1:15 PM) [snapback]664150[/snapback] QUOTE(Bitter @ Apr 13, 2008 - 11:23 AM) [snapback]664116[/snapback] he replaced the rod bearings? and only the rod bearings? wtf mate. if your engine was damaged enough to need new rod bearings then odds are the crank should have been taken out, mic'd, turned, polished, and while you're at it do the main bearings as well. thats like putting a plug in a bald tire, sure it works but you need a new tire. understand what i'm saying? i hate when shops just go for the quick and easy fix rather than doing it right. it makes me sound bad when i tell someone they need an engine because they have rod knock and they say 'well the shop down the road can do the rod bearings for $500 instead of the whole engine'. plugging a bald tire. well he was just going to replace the radiator but he heard the engine was knocking so he just replaced the rod bearings so i wouldnt hear the knock. He told me the crank isnt damaged that bad. All he charged me was $250 US. He also did and oil change and replaced the spark plugs. Im gonna have the engine rebuilt soon. No, there's no knock and Oil Press. is perfect. |
Apr 13, 2008 - 7:27 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
So correct me if I am wrong. Mar 8 you posted about the rod bearing.
Then apr 1 about the radiator. Did you drive it with a spun rod bearing for that span of time? If so your crank is likley toast. -------------------- JDM guy made me do it.
Apr 13, 2008 - 10:47 PM |
i drove 60 miles w/ a rod knock and very little oil.
had to. mommy didn't know i left town. i had just got my license/car. i was an idiot This post has been edited by stephen_lee: Apr 13, 2008 - 10:49 PM -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Apr 14, 2008 - 3:16 AM |
QUOTE(97lestyousay @ Apr 13, 2008 - 7:27 PM) [snapback]664236[/snapback] So correct me if I am wrong. Mar 8 you posted about the rod bearing. Then apr 1 about the radiator. Did you drive it with a spun rod bearing for that span of time? If so your crank is likley toast. yea i did drive it with a spun rod bearing.....but he said the crank wasnt damaged thats bad.....i dont know what "that bad" means....but im gonna rebuild the engine anyway. -------------------- lol
Lo-Fi Version | Time is now: January 11th, 2025 - 10:42 AM |
